Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Meat-Head's Avatar
    the last post in this is nearly a year out of date
    funny though was in a eleator rin block of flats last nite in there was ambulance crew on way to a breakdown bloke was saying about a company called autolec on the isle of white can emulate the later honds
    but then he ran off
  2. #17
    Cepe Verde
    how to solve this problem i have exactly the same problem. i remove the board and the car didn?t crank. now i remove the 9346 inside the immo box. i have the black key with data and i need to write the key data to the 93C46 chip. If some one can tell me how to write it.
  3. #18
    Meat-Head's Avatar
    feeling of dejau vous just had a thread like that
    yeah must get roud to writing up what i did with the other one i had.
  4. #19
    Cepe Verde
    i couln?t understand you. any way thanks a lot. But i still need help to write the key data to the immo dump.
  5. #20
    Meat-Head's Avatar
    Quote Originally Posted by ssemmedo View Post
    YES PLEASE that would be aswesome if you can figure it out thanks.
  6. #21
    Cepe Verde
    I?m trying to solve this situation. i take out the small board inside the ecu the car did not start; i read the 93C46 eeprom inside the immo box and i post it here in DK; i read the M851G eeprom on the immo pcb and i posted it here in DK; e have the zedbull clone with one i read the Black key data. Now i wanted to know if there are some one to help me writing the key data inside the immo box eeprom 93C46. I?d apretiate and i can pay by paypal if the help solves my problem.
    Best regards.
  7. #22
    Cepe Verde
    The immo box in this case don?t let the starter work. in this case try to locate the relay under the steering wheel and shorter it. the car will crank and start if you are locky.
  8. #23
    Meat-Head's Avatar
    Ok so how did you fix the immo,(?
  9. #24
    Mar 2013
    Or put a jumper wire in immo box connector from pin 3 to 8 so starter will work .Also jumper from pin 5 to 6 on 10 pin connector so you can do diagnostic .
