What you want to do ? Immo off or repair ?
sorry ;O)
im*o off
Inside the ecu has a little board with OKI M851G . Remove it and the engine will started !
oaky done its only the serial eprom i need 2 remove ??
Remove little board with OKI ! No only OKI !
Here is it
Seem to think, the word on the street is the MIL will be on.
Honda - IMMO but this is was 96 think it was at top of page
i have know desolder the hole one you have marked whit red.. and when i try 2 start the car the starter do not do anything ??
I can help you with immo code if you give me the vin of the car.
hi all
Honda cars year 1995-1998 (Civic, Accord and others). Inside immo board looks
like in picture. On this board is small 44pins processor and OKI M851G EEPROM
(you can read/write it like 93C46). Most common problem with this type
immobilizer is IMMO-ECU synchronization lost (this happens when ignition are
switched ON withred key). To solve this problem just erase OKI M851G
EEPROM to FF...FF.
To disable immobilizer just remove immobilizer board (marked in red on photo)from motor ECU. Honda immo emulator is no needed for this kind of ECU.
