hi ya mate what display do you have cid, gid?
rob
hello,.
Is there anyone that have programmed the index code (DISplay) on an Vectra C ?
If yes, how did you do that ?
i have an 2004 modell that do not have Board or Trip Computer
and i found that i can change the index code to make it become an Board // Trip Computer
so if someone can help me on the way i have been happy..
NIGHTCD
rob
no one ???
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
Boys, do you know the code for Corsa's GIDs?
Because in this pdf there is not any code about!
You can`t change index code with clone opcom. We must waiting for crack to the newest version 2010 year.
For now - only TECH2
@holmes83
Do You have computer? Verify 32 pin with 18 cables. If You have change with TECH2 index code - 002
Yes, I've BC.
How is the procedure to verify 32 pin with 18 cables?
Unfortunately I've not the TECH2 only OPCOM...
i've got my tech2'd and i have now the border computer, but is missing check control. anyone know if i can program check control with opcom? if yes ,, how to..
the opel mechanic that did it for me said to add 1 to the number that your display got.. exs.. if you have 007 then it should be 008 :-)
You can not change index code with the opcom, only one which can do that is opcom 10 new version but it's unusable or you have to have an original Op com
otherwise tech2 and code index is in TIS, this index depends on your display and your fuel gauge and if you gave BC
For BC you have to use 009 if you have linear fuel gauge
Ok people ..seems that you dont take the NO SOFTWARE . ban seriously .. well think about it now ... you have time ...
