i will try it all to get my dm 500 back to work
Good evening, I have a dreambox 500 clone and I have tried with image dreamup 1.3.3.4 but there are cops failed flash error RC 1572 992 Box Will Be unusable now thank you for your help
after turning off dreambox500hd, has error message after loading enigma with crash log. How can I fix and with which program to upload which version of image of enigma?
I'm having the same problem. any help please
y i cnt download any file frm here?
Time limit before you can download after making a post and if i had my way it would have to be a meaningful post after you you have made an introduction.
Introduce Yourself
Andy,
having the same issue,i flash erased with dreamup.then i flashed with erase file image given a few pages back,but when i try then to flash with a image of my choice i get the same error as everybody else,I want to put commamdo 14.6 on my box,but i get error message,so i cant install it.why is this? Any way around it?
i have prob with DM500 it does not respond to the remote control and no image
If you see a DreamUp message like "found no valid JFFS2 in image" then it means you're flashing an image like Commando 14.6 that has had the /var_init folder in the root SquashFS partition surgically removed to save space in /var
Don't press the <Flash erase> button, just press <Flash>
Cheers- AL![]()
Have the same problem with dreamup not "seeing" my old d500s,runnign out of patience with it now![]()
My DM500s says:
Unable to read configuration data
--- Device Con Power-On Test DevProgram exception
SRR0=8x SRR1=8x
Die ... :-(
After flash with DreamUp
Any ideas?
After running this exe program, it tries to connect to the internet - only my firewall stopped it?
If its a proper patch (with nothing hidden), it should have no reason to connect to the internet - sameway dreamup works without needing an internet connection?
I might be a newbie here, but I'm sure as hell not 'wet behind the ears' and have to ask the question WHY it wants to connect?!
Such programs make me damn suspicious.
