Results 1 to 14 of 14
    Nov 2018
    Tucuman- Argentina
    Default Ems2 Mini cooper
    Hello good afternoon, could someone help me with an immo off on mini cooper ms2 with flash 29f400bb29f400bb minicooper 118012003b.rar
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    try these files and let me know if it's okay or not
    YOU MUST correct cheksum inside if not the car not start
    your programs device should normally do cheksum Pass PM
    DISCONNECT IMMO BOX EWS and connect the two thick cables together for the starter
    Please Press Thanks Button and Reput if i helped !
  3. The Following User Says Thank You to Hayssam1 For This Useful Post:
    mkii (14th October, 2024)
    mkii's Avatar
    Oct 2008
    Quote Originally Posted by Hayssam1 View Post
    excuse me (I'm in no way questioning your abilities) but a few years ago I did an off on a r53 cooper in flash without touching the EWS!!!
    MKII
    Think Thx an rep buttons !!!
  5. The Following 2 Users Say Thank You to mkii For This Useful Post:
    Feder1592 (13th October, 2024)
  6. #4
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    you are right you can try as you think
  7. #5
    mkii's Avatar
    Oct 2008
    i try ...............
    test and report please
    MKII
    write with V54 protocole siruis32
  8. The Following User Says Thank You to mkii For This Useful Post:
  9. #6
    Nov 2018
    Tucuman- Argentina
    Quote Originally Posted by mkii View Post
    Intento ...............
    probar y reportar por favor
    MKII
    escribe con protocolo V54 siruis32
    Hello, I read the flash drive outside.
  10. #7
    Nov 2018
    Tucuman- Argentina
    ¿Está listo ese archivo para grabar? No sé cómo realizar una suma de comprobación.
  11. #8
    mkii's Avatar
    Oct 2008
    no chks in immo off !!!
  12. #9
    Nov 2018
    Tucuman- Argentina
    ¡¡¡No se permiten comprobaciones en el inmovilizador!!!
    I just plug in the ecu without disconnecting anything?
  13. #10
    mkii's Avatar
    Oct 2008
    yes ..............................
  14. #11
    mkii's Avatar
    Oct 2008
    any news ???????????????????????????
  15. #12
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    exactly what I hate, I also take time for the people and no answer
  16. The Following User Says Thank You to Hayssam1 For This Useful Post:
    mkii (17th October, 2024)
  17. #13
    Nov 2018
    Tucuman- Argentina
    buenos dias , tuve un problema de salud , ay que preguntar antes de hablar boludeces, ahora pruebo y le aviso , beso en *
  18. #14
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    Quote Originally Posted by Feder1592 View Post
    I wish you a speedy recovery but please write in English
