Results 1 to 12 of 12
    netherlands
    Default honda cbr600rr 2007->
    I have here a tacho from a cbr as title and the km must be changed.
    it now have 3573km, and must have 6500km. Yes more km's than it has now.
    I was looking for the eprom, but do not know if it is the one from the picture. Can someone confirm and help me to change it?
    on the eprom in the picture is D3950
    best regards, johnny
    gepakg's Avatar
    Serbia
    bad picture quality,do you have some chip in TSSOP pack,signed l56r?
    regards Gepa
    Quote Originally Posted by sjonv View Post
    search on the 2 side.
    8smd 93c56
    netherlands
    oke, i wil remove the rpm needle en plastic case. It's behind there?
    netherlands
    nothing found like l56r, i found hc740, 6h1y and other are unreadable.
    will try electro28 advice.
    br
    johnny
    netherlands
    oke i have opend the second side, but there is nothing under the displays.
    another suggestion, or is it the 8 pin in my picture.
    i tryed to google d9350 but not succeed.
    Someone now what eprom this is?
    br
    johnny
    gepakg's Avatar
    Serbia
    for sure this dash use 93c56 but in tssop pack,please post more quality picture to sign it!
    regards Gepa
    br
    johnny
    Member jasonk's Avatar
    Ireland
    Did you look here :
    http://tachosoft.com/pics/b_hondacbr600.htm
    netherlands
    here a better image,
    i think the 93c56 is d9350.
    can you confirm?
    I have your first picture with circle at 93c56 TSSOP, yes the small one.
    I use clip for it, but before i've took it off and wired it up pin by pin.
    If you read with diga you can just use honda cbr600F1.
    By the way, this looks damn much of a picture i've made, especially the table where it's on, i go look for the picture i've made.
    Gook luck, tellerkoning nl
    here's my original pic:
    I don't know witch part of holland you come from but if you need help....
    Nov 2020
    North London, UK
    Probably too late to the party but might help someone
