Results 1 to 8 of 8
    Jan 2019
    Default EDC15P+ IMMO SOLUTION
    Hi, can someone enlight me or have file with immo off solution on flash am29f400bt?
    Its possible to do so, just want to confirm how its done, are addresses 530A5 and 730A5 with values (00050 and 00300 depending on flash dump), correct? And so how to modify them for the immo delete?
    I attached a stock flash readout if someone can make it, id truly appreciate it!
    mkii's Avatar
    Oct 2008
    edc15p+ immo in eprom !!!!
    Think Thx an rep buttons !!!
    brend's Avatar
    Oct 2015
    Same where
    Also with actual key very easy .......
    Get login from dump , vcds - / + 2 min job and done.
  4. The Following 3 Users Say Thank You to brend For This Useful Post:
    Hayssam1 (31st October, 2024), mkii (31st October, 2024), rafal (31st October, 2024)
    Jan 2019
    Need in flash, its do-able
    Jan 2019
    Fuel cut off disable in flash, so it always starts any key
    Jan 2019
    Someone able to make it?
    kiszka's Avatar
    Quote Originally Posted by AR REMAP PORTO View Post
    Why do immo off in flash if you can do immo off in eeprom?
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Jan 2019
    Quote Originally Posted by kiszka View Post
    To be able to have multimap with VIN secured purpose
