Your very right about the fuel wire. tricked that out and it helped more than anything ive tried so far. VERY PLEASED on that one. What flash file r u useing for that 625 2300?
Hey guys wondering if any one has 2007 flash files? I searched the forum and didn't come up with any results.If anyone happens to have them it would be very much appreciated.Thanks
hey guys i really need a flash file to make a 435 6nz in to a 475 1850. best file please. thanks much
Wrenchead a 435 6nz has many different hard parts than 455 and above 6nz. The pistons are different they are 18:1 comp ratio where as the higher hp ones are 16:1 the cams are different also along with the injectors and turbo. You can uprate it to a 450 wich is a field uprate only without changing any hard parts.
Hi does anyone have caterpillar flashfile 2707067 ?
Please Members, I need your help with this flash file 1735945, thanks in advance, regards.
Greetings, I have an EMCP3.2 controller on a genset, and I need to flash it. It has the following info:
Part No.: 3007646-01
S/N: 1648B059TA
Software Part No.: 3222198-00
Software Date: NOV2007
Software Description: L1 6_0 Standard -- Spanish, 2.2 Prod, 7Nov2007
Does this mean that the flash file I need is 3222198-00? If so, Can anybody share it? I have on my flash files: 3222197.FLS and 3222199.FLS
Thank you all in advance.
SOME PEOPLE SEE THINGS AS THEY ARE AND SAY WHY... I DREAM THINGS THAT NEVER WERE AND SAY.... WHY NOT????
Please, I still need your help with flash file 1735945
Thanks in advance, regards.
these were derated 475 1850. should be ok. thank you though for the help
