Page 6 of 101 FirstFirst 12345678910111656 ... LastLast
Results 76 to 90 of 1502
  1. #76
    Member andreytora's Avatar
    IF some body can help me with all flash files for 330D S/N:T2Y00386
    Thanks in advance!
    Who not with us - that against us, and no hatred - a work only!
  2. #77
    Mrhemi that would be great if you could upload that the older pre low nox flash files are hard to come by.
  3. #78
    These are 2000 flash files not 2002.
    Hopefully someone will find them useful.
    Disk 1 - http://rapidshare.com/files/446096104/RERA902023.rar
    Disk 2 - http://rapidshare.com/files/446087075/RERA902110.rar
  4. #79
    DK Veteran RSwire's Avatar
    your girlfriends house
    Quote Originally Posted by andreytora View Post
    Thanks in advance!
    Done........
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  5. The Following User Says Thank You to RSwire For This Useful Post:
    dupisa (19th June, 2014)
  6. #80
    Quote Originally Posted by mrhemi View Post
    can u please reupload thanks
  7. #81
    Quote Originally Posted by toshor View Post
    The files are still there and should be working fine.
  8. #82
    Member wrenchead's Avatar
    Nov 2010
    Quote Originally Posted by sreeindia View Post
    Any body have flash file no:192-9953 and1606814. thank you in advance
    here you go
  9. #83
    Nov 2010
    Default old flash files i think
    dont now how old they are
  10. #84
    Jan 2011
    Do the flash files have to be from the same version of ET that I'm using or can they be from any version?
    Darren
  11. #85
    Default HP upgrade 3406E 6TS17087
    I need to upgrade HP to 500 or more. Does anybody know what flashfiles I need? The newest one i think is 1869901 - which is low nox(that I don't want) with a high IC.
    How does one know what files can be used with one serial number and what the HP settings are? Using ET this serial number comes up with 1869901, 1708156, and 1572953. The newest one is 1869901. Are all these going to be the same HP. Can a person use a different flash file than these?
  12. #86
    Top Poster SaMirakle's Avatar
    Jan 2011
    Quote Originally Posted by frankiegr View Post
    If you give me the engine serial number I can tell you what the flash file history is on it. (Original flash file for that engine when made plus all of the updated flash files created for it) M
    My source isn't ET. It's actually through Caterpillar.
    ---:..Gratitude is the best attitude..:---
  13. #87
    The serial number is 6TS17087
  14. #88
    Jan 2011
    Here is the flash file number history for that ESN: (Recent to oldest)
    1869901 (most recent)
    1708156
    1572953
    1469196
    1437520
    1344709
    1297749 (first flash file)
    Hope that helps
  15. #89
    Do you know if any of these flash files are more than 435 hp? If none of these are more than 435 hp, can I use a different 6TS flash file that has more hp? Like a 475 or 500hp 6TS flash file
  16. #90
    Those are all going to be the rating that came out of the factory. If it started life as a 435 I don't think it can be uprated past 450 without changing internals.
