Try This My Friend...
Monitor.zip
Engine.zip
Powertrain.zip
Monitor.zip
Engine.zip
Powertrain.zip
stewars (7th January, 2021)
Does anyone have the original flash file # 130-7115. Not looking for a lo nox replacement.
Thank you
Looking for the latest flash file for c7 Serial number SAP05273
Thanks In Advance,
3000448.FLS.zip
Rendyrehan (6th June, 2021)
I am being told that i need flash File 300-0465...
Might you have this one also?
Thanks In Advance...
MaksimNov (19th March, 2021), Rendyrehan (6th June, 2021)
Thankyou, Kind Friend
Looking for flash file 270-7028, C12 430hp. Any help appreciated
Insp851 (26th January, 2021), MaksimNov (19th March, 2021), Rendyrehan (6th June, 2021)
Why not ET Communication with ECM? When i try to connect et with ecm this time CDL & J1708 led is flicker of the ET but does not communication with ecm? What is the problem? How can i solve it? Is it possible to flash ECM in this situation? Engine type CATC-32, Serial Number - SXC05285. Advance thanks
When you connect Cat ET to the ecm the lights will flicker then should stay on steady. It is possible that the ecm is bad. If it is then no you can not flash it. You must have a constant connection. Try any other cat ecm to see if your Cat ET software is working correctly.
Shezan (27th January, 2021)
Apparently the ecm you need is no longer communicating. You will need to get another one and flash file it to your vehicle.
Shezan (2nd February, 2021)
