on a a3 2.0d 2005 year the engine(BKD) starts hard when it is hot .. please help , ecu dump ( with galleto 1260 ) , tanks in advance and sorry for my bad english .
what you need immo off
not immo off... i have the key ... the engine does not start propely ( starts after several seconds ) i think the glow plugs are not powered enough
post diagnostics results, dtcs from all modules
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
If ECT sensor is good you need resoft ECU.
Post the dump !
it's known problem in Audi & VW cars , when the car is cold
it starts without any problem , when it's hot , it's diffuclt .
in French we call that " D?marreur "or Starter it needs to be change .
hope helps
Yes it is true. The problem is in lower engine rpm while cranking!
But this problem can be also solved with soft remap .
i know i need a remap here is the dump
You must to check your PM box !
Regards !
..well my friend I am old school car electrician..so first step should be to check RPM when you start youre car..compare it with cold/hot start..IF this is OK (very rare is OK) then you can use 1 resistor 1 diode and one small relay..conect this 3 parts so engine ECU always have info that engine is only-5 c. so glow plug is ON on every youre start..of course you dont need to wait whole time for glow period to pass..on hot engine 2 sec will be fine..car start with first turn the starter..when engine is runing alternator via diode simple engage relay from begining of this long post,relay will bypass resistor and ECU will receive corect measurment..so nobody fools the ECU when engine is runing...or you can play with dumps/flash....but my first solution is always this upper story probaly old school tricks
regards!
tanks to VOLUMAX and the rest of you ... after resoft car starts ok![]()
Raga also my car has this problem, like fixing? volumax rar file has the password and cannot see how it worked out: (
DO you change a clutch? if you did then it is possible for the problem. I have that situation on GOLF 5. I work as carmehanicar
