Results 1 to 3 of 3
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Toyota Corolla cluster compatibility
    I'm looking for a replacement cluster for this 2019 corolla and see several with slightly different numbers but from display and rear plugs are the same does the numbers need to be identical?
    Nov 2020
    Hi, different numbers means different firmware, the possibility of check engine would be on or other warning lamps
  3. The Following User Says Thank You to Nightdriver For This Useful Post:
    teerak2uk (12th November, 2024)
    fuzz1's Avatar
    Jul 2019
    It's a ten minutes job. Just plug it in and see. Normally if it's for automatic or manual and you plug it for same it should work.
    And copying the chip data to the new cluster will bring you back to the original. Works most of the time
  5. The Following User Says Thank You to fuzz1 For This Useful Post:
    teerak2uk (13th November, 2024)
