    DK Veteran deffc0n's Avatar
    UK/POLAND
    Default [PLUGIN] Newnigma2 OE1.6 dts downmix
    Newnigma2-Team presents:
    To explain
    With this plugin it is now finally possible a dts audio stream that is in many mkv containers include, without dts system simply downmix stereo speakers on the issue of the TV! This way you do now an expensive converting the audio stream to an external computer from dts to AC3 before you can watch the film.
    To use the new plug is at least one or Dreambox 500HD Dreambox 8000th The dreambox-TMPD "Genuine plugin must be installed and executed at least once been successful. The operation of the "dreamdts" plugin also covers libdca0_0.0.5 Newnigma2 unstable and a current image or a current dmm experimental image is necessary. The libdca can be drawn from the unstable feed.
    Known Issues
    - If the plugin does not run immediately on a DM8000, please call again until the "Genuine Plugin and follow, then it should work then there
    HERE:
    Nov 2010
    I take it this plugin wont work for the Dream Elite image ?
    Feb 2012
    i will try this on a clone
    Mar 2012
    does this work also in original images of dream ?
    Sep 2012
    thanks a lot...
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    anyone got it to work on a 800hd ???
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
