Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    DK Veteran tomaszcz's Avatar
    ZGP
    Default renault Kangoo 1.9 lucas i*mo
    Hi alll Friends. Renault Kangoo 1.9 Lucas DCU3R pomp delphi .Can you help me? I *mo killer and cartool does not work. Has anyone on this idea?
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    dump immo off Cut pin 20 immo line ECU
    ZGP
    Write your dump and does not work. I try WP pin to gnd and does not work.Probably needs to be emu.
    Does someone have an idea?
    Morocco
    you want to say the pin wp was holdup and joined to gnd
    ZGP
    Started only once after changing to off file dump.Second time will not start.I try WP pin to GND and does not work.
    ZGP
    I think I need to replace the chip because it has no write protect
    Morocco
    remove eeprom it will start
    ZGP
    Take a look on monday .Thank you Mate.
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    YOUR EPROM 25080 OR 95080
    yasser's Avatar
    Bulgaria, Varna
    what year is that car?
    Spain
    If ECU is a Lucas DCU3R finished in 29C without memory doesn?t start.
    No problem in inmo or ecu, problem of this cars is UCH.
    If you insert your key and red led flashes very fast, the problem is that your key and UCH changes status and is different between two. You must put in same status and car start without problem.
    ZGP
    Car year 2000
  13. #13
    hi,
    please open the key and check the transponder coil , also resolder the smd chip inside.Problem is very often the key!!
  14. #14
    Busswil Switzerland
    i have done many dcu3r ecu only remove eeprom from board and car starts.
  15. #15
    ZGP
    No memory works, but limited engine rpm.
