Grundig Radio in safe mode
Results 1 to 15 of 15
    Lightbulb Grundig Radio in safe mode
    Hi all,
    I'm looking for a way to recover my grundig radio in safe mode. I've been able to read eeprom data (or I think so), but I'm unable to find the code inside the dump. I've read that it can be found at address 190-0 and 190-3 and I've also read that address 00010 have the standard Grundig algotihm, but I don't know how to get the code from inside the dump.
    Attached is the dump. Can somebody explain me how to read this dump (dumped with PonyProg) to obtain the code numbers. I've tryed with Hex editor with no luck.
    Best regards.
  2. The Following User Says Thank You to hastaelnabo2000 For This Useful Post:
    camonei (13th January, 2021)
  3. #2
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by hastaelnabo2000 View Post
    Hi all,
    Best regards.
    Your code is : 1441
    alexics's Avatar
    Kidderminster
    Hi all,
    Best regards.
    You will not get any help if you don't give any model info. What are we supposed to be looking at??
    alexics's Avatar
    Kidderminster
    Your code is either 1441 or 1357 depending upon what the chip type is. Try both and let me know.
    Many thanks!!!!!!!!!
    Correct Code is 1441. I don't know exact model for this radio, is a Grundig Radio CD for a Smart Car.
    Can you explain to me how can you find code 1441 in dumped file? I've tried with hex editor, but I've found nothing. What must I do to find it? I need any special tool?
    Thank you again.
    PS. Chip is 24c08 (only printed as 08 at mainboard).
    alexics's Avatar
    Kidderminster
    Thank you again.
    Many years back the original radio to use this method was the grundig 3841. It took us quite a while to break it in the 90's. It involves xoring various values together. I won't be publishing the method on a public forum as it was hard work and only through hard work can you gain experience. Line 0010 is where the code is. :-)
    Thank you alexics, I've found a tool called "GRUNDIG WKC Series Code Calculator 4.00". Is very simple to use, I only need to fill the fields in the tool with data from line 00010 and press the button "Check my Dump". I still dont'n know if the program use XOR with Hex Bytes or Ansi String, but code returned is correct code. Thank you for your help.
    Hello, could you give me radio code for SC 303(b). This radio is in Opel.
    Sn on this radio is GM0303A1403432
  10. #9
    Default radio code sc 303 (b)
  11. #10
    I need radio code for smart for two. Please help me.
    MC1200X1387749
    Smart radio CC
    0001200
    V007
    0000 00
    9.18344-8151 G.HH 76-00
  12. #11
    DECOCO's Avatar
    north east
    Quote Originally Posted by Macijauskelis View Post
    for this serial number doesnt work after serial you have to read the mcu
    all best
    work to live
  13. #12
    Member ADRIANALEJANDRO's Avatar
    ESPA?A
    HI,CAN YOU PLEASE GIVE ME CODE TO SEAT BRISA V3
    SEZ2Z5B1532775
    1M0 035 152C
    THANKS
  14. #13
    Quote Originally Posted by ADRIANALEJANDRO View Post
    SEZ2Z5B1532775
    1M0 035 152C
    THANKS
    24LC16 dump post here
    not calc serial..
  15. #14
    ESPA?A
    SORRY,WHAT IS THIS NUMBERS? I?DONT NOW.SORRY MY LANGUAJE..
    02 55022 0330153277 5 ?
    021414?THANKS
  16. #15
    Jan 2021
    I have the same chip from the eeprom but I can't download this dump to compare.
