Suzuki Gsxr 600 93c56(L56R) help
Results 1 to 13 of 13
    6
    Downloads
    402
    Uploads
    Default Suzuki Gsxr 600 93c56(L56R) help
    I look for dump Dashboard L56R to Suzuki GSX-R600 K1-K3.
    I look for still correct power supply, he does not work from tachosoft.Suzuki GSX-R 1000 spedometer calibration pics - odometer Suzuki information
    6
    Downloads
    402
    Uploads
    Dashboard is also in Suzuki GSXR 750
    didi_du_93000's Avatar
    France Paris
    241
    Downloads
    23
    Uploads
    Hello, you must read the L56R (is same as 93C56)
    read and post i can elp you.
    Downloads
    Uploads
    I'm trying to read that same chip on 750, is it possible to read it without desoldering it?
    Is that L56R exactly same than 93C56? ( so that all pins match and no short circuit appear )
    Zagreb
    Downloads
    Uploads
    Quote Originally Posted by skode View Post
    Its possible, you have service points behind clock, but I take no risk so I dessolder it ad then read.
    5
    Downloads
    9
    Uploads
    i only use service points, i have backup from this type tacho.
    worst case is you lose the dump, take a backup dump, write it, problem solved.
    There are 2 versions of the print inside.
    uk
    229
    Downloads
    Uploads
    Quote Originally Posted by klostazy View Post
    check the circled area i am sure this is your eeprom...
    6
    Downloads
    402
    Uploads
    Quote Originally Posted by r-parts View Post
    please backup dump
    Quote Originally Posted by raf0468 View Post
    the next is eprom
    not possible to read it without desoldering it
    UK WEST YORKSHIRE
    6
    Downloads
    68
    Uploads
    Default gsx power up
    this is what you need pass in pm
    Downloads
    Uploads
    what tools are people using when desoldering eeproms?
    I have vacuum desoldering station but I guess thats not suitable for SMD?
    I have ordered chipquick... maybe I need to just wait for it to arrive
    Downloads
    Uploads
    Same problem... where are the service points? Is it possible to read it with the unit listed on ponyprogs website?
    Downloads
    23
    Uploads
    hello
    tomorrow i will receive a gsx r 1000
    it is possible read and write mileage with a labtool 48 uxp and pin points
    i have a pdf with pin points behind tacho for not remove display to access eeprom
  13. #13
    Downloads
    Uploads
    Quote Originally Posted by figo95 View Post
    hello
    maybe yes , maybe not .... think about what is happen if something going bad ...
