Results 1 to 13 of 13
    Dec 2009
    Poland
    Default Suzuki Gsxr 600 93c56(L56R) help
    I look for dump Dashboard L56R to Suzuki GSX-R600 K1-K3.
    I look for still correct power supply, he does not work from tachosoft.Suzuki GSX-R 1000 spedometer calibration pics - odometer Suzuki information
    Dec 2009
    Poland
    Dashboard is also in Suzuki GSXR 750
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Hello, you must read the L56R (is same as 93C56)
    read and post i can elp you.
    Apr 2010
    I'm trying to read that same chip on 750, is it possible to read it without desoldering it?
    Is that L56R exactly same than 93C56? ( so that all pins match and no short circuit appear )
    Sep 2009
    Zagreb
    Quote Originally Posted by skode View Post
    Its possible, you have service points behind clock, but I take no risk so I dessolder it ad then read.
    Nov 2009
    i only use service points, i have backup from this type tacho.
    worst case is you lose the dump, take a backup dump, write it, problem solved.
    There are 2 versions of the print inside.
    Jan 2010
    uk
    Quote Originally Posted by klostazy View Post
    check the circled area i am sure this is your eeprom...
    Dec 2009
    Poland
    Quote Originally Posted by r-parts View Post
    please backup dump
    Quote Originally Posted by raf0468 View Post
    the next is eprom
    not possible to read it without desoldering it
    DAHDOC's Avatar
    Jan 2010
    UK WEST YORKSHIRE
    Default gsx power up
    this is what you need pass in pm
    Apr 2010
    what tools are people using when desoldering eeproms?
    I have vacuum desoldering station but I guess thats not suitable for SMD?
    I have ordered chipquick... maybe I need to just wait for it to arrive
  11. #11
    Jul 2010
    Same problem... where are the service points? Is it possible to read it with the unit listed on ponyprogs website?
  12. #12
    Mar 2010
    hello
    tomorrow i will receive a gsx r 1000
    it is possible read and write mileage with a labtool 48 uxp and pin points
    i have a pdf with pin points behind tacho for not remove display to access eeprom
  13. #13
    Apr 2010
    Quote Originally Posted by figo95 View Post
    hello
    maybe yes , maybe not .... think about what is happen if something going bad ...
