*REMOVED LINKS*
*REMOVED LINKS*
NP, hopefully u have a good connection! I have 100mbit here and 5up and it still took me 4 hours to dload it all to test!
hello,
I just wanted to ask you why the DVD 6 begins from rar part nr.8, like the others DVD ?
thank you in advance
good question i will fix it
I am uploading them now somehow i missed that. check back in a hour and it will be done
oke thanks any body have the latest flasch file disk?
CD6 Fixed and i dont have the FF cds
have set up disk ? RERR0010 is data disk
thank you is a great job and very time inverted thank you again
i am not posting installers! they are all over this board look around you can find SIS or STW on here with no problem
Which program is used to join the file after the extract with WinRAR. I try with Hjsplit 2.4 but is no good.
It is Virtual CD, any version above 7 should work.
THANKS 4 SHARING SIS 2010.GREETINGS FROM GREECE.![]()
...what include these CD's?
Caterpillar SIS = Service Information System ( part book and shop manual)
One safe source
Oring dimension and material
Exhust dimension
Undercarriage dimension
Bolt dimension
Special tools
Caterpillar Disc #1: TRUCK ENGINES, TRACK MATERIAL HANDLERS, ELECTRIC POWER GENERATION, EST, LOAD HAUL DUMP, INDUSTRIAL ENGINES, MARINE ENGINES, EMAC
Caterpillar Disc #2: MACHINE ENGINES, INDUSTRIAL ENGINES, MARINE ENGINES, ELECTRIC POWER GENERATION
Caterpillar Disc #3: ELECTRICAL POWER GENERATION, INDUSTRIAL ENGINES, MARINE ENGINES, MACHINE ENGINES, COMPACTORS, OEM PRODUCTS , WHEEL TYPE TRACTORS
Caterpillar Disc #4: WHEEL TYPE LOADERS, WHEEL TRACTOR SCRAPERS, WHEEL TYPE TRACTORS
Caterpillar Disc #5: EXCAVATORS
Caterpillar Disc #6: ARTICULATED DUMP TRUCKS, ASPHALT PAVERS, BACKHOE LOADERS, COLD PLANERS, MOTOR GRADERS, UNDERGROUND ARTICULATED TRUCKS, WORK TOOLS, INDUSTRIAL ENGINES, ELECTRIC POWER GENERATION, MACHINE ENGINES
Caterpillar Disc #7: CHALLENGERS, COMBINES, EXCAVATORS, INTEGRATED TOOLCARRIERS, ON HIGHWAY TRUCK, PIPELAYERS, TILLAGE, TRACK TYPE TRACTORS
Caterpillar Disc #8: ROAD RECLAIMER, TRACK TYPE TRACTORS, TRACK TYPE LOADERS, TRACK TYPE SKIDDERS, SKID STEER LOADERS, INDUSTRIAL ENGINE, MACHINE ENGINE, TRUCK ENGINE, EXCAVATORS
Caterpillar Disc #9: EXCAVATORS, COMBINES, MINI EXCAVATORS, FORESTRY PRODUCTS, WHEEL SKIDDERS, MINI EXCAVATORS, LOAD HAUL DUMP, TELEHANDLER
