I realy sent to you the very thanks for the licence...
I have the question ,,,,What program do you use for licence????
Windows 7 64bit and 32bit both work great with ET and SIS
But.. some "others" have not make there programs work with the 64bit systems! But Windows 7 32bit works GREAT with most of the software I have tried! And.. that's Quite a few! I would say! Microsoft Did a VERY Good job with Windows 7, For being backwards compatible with most of the "Older" software... IMO and that's my 2cent's at least! I hope that helped someone!
PS..
Did you know if you have a laptop running a 64bit OS and you need a 32 bit OS.. all you have to do is download the 32bit system from a torrent ... Format, Install the New 32bit OS and use your old 64bit SN from the bottom of you laptop, Install the new OS, After its all done it will say it is not genuine.. and will not activate over the internet!All you have to do is call it in and they will do it all for you over the phone! I just find that awesome.. that they will let you do that cuz.. they dont have to! ... just nice to know I guess
Import SIS Users Sorry, failed to retrieve the user details.
How can I load the user file, thank you!
I have the same problems....I open the sis 200b and apears logins and passwords,,,,,I import user in format xml and them use the login and password The login id and/or password entered are not correct,,,,,Some one help me about the sis user?????? I use several (import user ) but i can not find good news
Later i hv same problem to ...
Solution: This problem cause when your using Sis online
reinstall your WIndows reinstall sis then import ... ITs work fine for sure![]()
Please help me, I need the license key for my ET tools with license code D002 E5DD BF79 3F4A 26 and license key for my SIS 2009 with license code SS 2919 5A8F AD2E 9B45 68.
Many thanks for your Help....![]()
Hi friends,
i installed and successfully logged in, searched and found parts but screen does not show image. Anybody could suggest any hint ? Thank you.
Hi! Guys,
I've the same problem of CAPVAM.
tried all tips but nothing... when restart SIS it ask me for license evey time and licence code change every time.
I use XP PRO SP3. CAT STW2009B + RERR0010.
Keygen "et2k9c_kg" by Sultan.
I attached some screenshot of activation steps..
Can you help me please?
My last license code for SIS is SS 1400 C8C9 1EA7 77BE 2603 E910
Can you generate a license to try if my keygen is not working at 100%?
Many thanks in advance. Rav.
The solution is as follows:
1st Find on forum program CATERPILLAR ET 2010A, and download
2nd Install ET
3rd run ET
4th Create a key with a keygen which had (ET 2009C)
5th install SIS program (as what you did)
6th Run the SIS (the program you will not ask for key)
Greeting
guys !
i need the license key for SS 5D14 4CAF B175 A68A 6D74 B45D
