Page 22 of 38 FirstFirst ... 12171819202122232425262732 ... LastLast
Results 316 to 330 of 565
Thread: SIS Feb2010
  1. #316
    Dec 2009
    I realy sent to you the very thanks for the licence...
    I have the question ,,,,What program do you use for licence????
  2. #317
    Jan 2010
    Quote Originally Posted by Roadrunner# View Post
    I don't use Windows 7.
    This is s... I use XP SP3 and all programs work excellent.
    Windows 7 64bit and 32bit both work great with ET and SIS
    But.. some "others" have not make there programs work with the 64bit systems! But Windows 7 32bit works GREAT with most of the software I have tried! And.. that's Quite a few! I would say! Microsoft Did a VERY Good job with Windows 7, For being backwards compatible with most of the "Older" software... IMO and that's my 2cent's at least! I hope that helped someone!
    PS..
    Did you know if you have a laptop running a 64bit OS and you need a 32 bit OS.. all you have to do is download the 32bit system from a torrent ... Format, Install the New 32bit OS and use your old 64bit SN from the bottom of you laptop, Install the new OS, After its all done it will say it is not genuine.. and will not activate over the internet!All you have to do is call it in and they will do it all for you over the phone! I just find that awesome.. that they will let you do that cuz.. they dont have to! ... just nice to know I guess
  3. #318
    Jul 2009
    Import SIS Users Sorry, failed to retrieve the user details.
    How can I load the user file, thank you!
  4. #319
    Jul 2009
  5. #320
    Dec 2009
    I have the same problems....I open the sis 200b and apears logins and passwords,,,,,I import user in format xml and them use the login and password The login id and/or password entered are not correct,,,,,Some one help me about the sis user?????? I use several (import user ) but i can not find good news
  6. #321
    Top Poster Snaz's Avatar
    May 2010
    Later i hv same problem to ...
    Solution: This problem cause when your using Sis online
    reinstall your WIndows reinstall sis then import ... ITs work fine for sure
  7. #322
    May 2010
    Default Hi
    Please help me, I need the license key for my ET tools with license code D002 E5DD BF79 3F4A 26 and license key for my SIS 2009 with license code SS 2919 5A8F AD2E 9B45 68.
    Many thanks for your Help....
  8. #323
    May 2010
    Hi friends,
    i installed and successfully logged in, searched and found parts but screen does not show image. Anybody could suggest any hint ? Thank you.
  9. #324
    Jan 2010
    Quote Originally Posted by xplorerz View Post
    Hi friends,
    i have awnswered this once allready.. why dont you read some of the older posts OR SEARCH FIRST before asking.
    very easy Fix. But since your lazy.. Figure it out its not hard.. please noone help this guy.. let me know what you find!
  10. #325
    Jun 2010
    Quote Originally Posted by CAPVAM View Post
    SORRY I PUT THE LICENSE KEY IN USER PASWORD AN WORK ALL GOOD, BUT IF NEED CLOSE THE PROGRAM AND OPEN AGAIN, IT NEED PUT LICENSE KEY AGAIN, HAVE THIS SOLUTION??
    Fix the problem as follows:
    Install CATERPILLAR ET 2010
    Run the program and when I requested a license key send me a license code.
    After inserting the key SIS you will not seek key.
    Roadrunner pls, i open the program, and put the key of licence, say license ok, and in the next time of open the program need again the licence key, any time of i need the program i need give the licence key?? can you help me pls
    I do not know how you installed the SIS, but I like this:
    1. install STW 2009B only SIS options on English
    2. install RERR0001 dvd on english
    3. start SIS from desktop
    4. put license key
    5. import user license and login
    6. and on the end everything works like FERRARI
    Unistall and install again on English.
    Perhaps resolve problem?
    When you install SIS on English and is everything is OK, open preferences and change language to Spanish!!
    Hi! Guys,
    I've the same problem of CAPVAM.
    tried all tips but nothing... when restart SIS it ask me for license evey time and licence code change every time.
    I use XP PRO SP3. CAT STW2009B + RERR0010.
    Keygen "et2k9c_kg" by Sultan.
    I attached some screenshot of activation steps..
    Can you help me please?
    My last license code for SIS is SS 1400 C8C9 1EA7 77BE 2603 E910
    Can you generate a license to try if my keygen is not working at 100%?
    Many thanks in advance. Rav.
  11. #326
    DK Veteran Roadrunner#'s Avatar
    Nov 2009
    Quote Originally Posted by rav286k1 View Post
    Hi! Guys,
    License key: 1E66 348F 678F 43F6 8AAD 76D3 44
    Your error is because you installed the SIS're using a keygen for ET.
  12. #327
    Jun 2010
    Yes!!! It work!!!
    At this point, where I can find a keygen for SIS 2009B??
    Or what is a right metod to generate a valid license key?
    I've 3 PC and I would like to install SIS on each PC.
    Thanks for your kind collaboration
  13. #328
    Nov 2009
    Yes!!! It work!!!
    The solution is as follows:
    1st Find on forum program CATERPILLAR ET 2010A, and download
    2nd Install ET
    3rd run ET
    4th Create a key with a keygen which had (ET 2009C)
    5th install SIS program (as what you did)
    6th Run the SIS (the program you will not ask for key)
    Greeting
  14. #329
    Jun 2010
    2nd Install ET
    3rd run ET
    Greeting
    Many thanks for your collaboration and detailed explanation Roadrunner!!!
  15. #330
    DK Veteran alcoholahmed's Avatar
    Jan 2010
    guys !
    i need the license key for SS 5D14 4CAF B175 A68A 6D74 B45D
