Results 1 to 10 of 10
    Default mitsubishi key programming
    where can i buy a tool that can program key to mitsubishi pajero 2001.i have t300[china],i connected with adapter for mitsubishi but cannot get communication
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    PROGRAMER FROM AD100 ORIGINAL IS GOOD
    T300 CHINA NOT WORCK FROM MUTSUBISHI
    Quote Originally Posted by ezenigbo View Post
    hi
    u can do it by speshell adaptor
    which adapter i should use?my t300 came with mitsubishi adapter ,i used it but no communication.i dont want to spend my money buying something that will not solve my problem
    nairobi kenya
    Default x431 and carman lite
    hi
    x431 and carman will do
    also my t300 does without problems no adaptor needed .obd cable only
    Yes, my T300 did it and i did not have to use any adapter, try it again without adapter
    DK Veteran marginal's Avatar
    Hello people.
    May I program an original Mitsubishi key fob or I have to unlock the transponder first?
    Also, do T-300, Diagun etc. have the ability to program the remote control part of the key fob?
    Regards.
    Est Modus in Rebus !!!
    keygargoil's Avatar
    it works fine with t300 but you must have the ignition to on before it will power up and if you switch it off it will lose power
    May 2011
    Illinos
    for your car, you can try the sbb key program, I have tried this and it works well for mitsubishi pajero 2001, and you can download this sbb car model...
    May 2012
    london
    hello, sbb its good for 2001 and i doing more keys for pajero and montero 2001 -2006
