Results 1 to 8 of 8
    Default Dead Dump 93C66 BCM Opel Corsa C
    Hello all.
    i have problem BCM opel Corsa C, not posible reset and program. i read dump 93C66 , But a thinks, dump corrupt, and not admite pin code.
    - Please help me and send , dump 93C66 BCM OPEL CORSA C
    SIEMENS
    3132038739
    5WK48664
    24 467 903
    0925 XB
    Serbia
    Default corsa c body
    corsa c
    pin 1543
  3. The Following 2 Users Say Thank You to mitin For This Useful Post:
    kastissu (16th October, 2015), putodaserra (3rd April, 2019)
    Thanks . mitin
    Sorry, but dump its SWAP ,
    i program eprom normal or swap ??
    I test.
    B.r.
    it depends on what programming hw u use...
    thnx, mitin..
    Hi!
    I have the same problem. The BCM is working correctly but I it doesn't accept the security code (the ECM and Immobilizer do... ).
    What programmer do I need to reflash it with that dump? After I do that, it will be "virgin" needing to be programmed into the the immobilizer?
    bump it! opinions wanted
    If anyone knows another process to "virginize" it would be even better. That way I could program it with a OP-COM... (currently the BCM doesn't accept the security code, but the other modules in the car do)
    bump it up!
