Page 321 of 322 FirstFirst ... 221271311316317318319320321322 LastLast
Results 4,801 to 4,815 of 4821
  1. #4801
    dom4n4k's Avatar
    Jun 2020
    Poland
    Quote Originally Posted by Kobylek View Post
    Attachment 1027556Hello. Please help me witch code for Chrysler? Its posible witchout eeprom ?Attachment 1027554Attachment 1027557
    Not possible
    Code radio ALL VAG (Skoda, VW, Audi, Seat) From serial and dump ACTIVE
    Code any radios
  2. #4802
    Mhamadnour's Avatar
    Nov 2018
    Hi all !!
    TOOBE212671541
    any help plzzzz
    Thank you ..
  3. #4803
    Jul 2010
    Bulgaria
    Hi, try code 1043
  4. The Following 4 Users Say Thank You to bogege For This Useful Post:
    Mhamadnour (25th May, 2024), pitgamy (25th May, 2024), REZON (25th May, 2024), shooting (25th May, 2024)
  5. #4804
    REZON's Avatar
    Mar 2015
    Ukraine
    Quote Originally Posted by dom4n4k View Post
    Not possible
    If it is not possible for you, this does not mean that it is not possible for others; out of three radios, only one was not found in the European dealer database.
    Code by serial:
    Chrysler: TxxQR;TxxAN;TxxQN;T0012;T0071;T00AM;TVPQN;T19A1;T1 9A2;T0MYD;T0BYD;T00AD
    MB Comand: NTG2.5;NTG4;NTG5
    Gathers: VSM145C;VSM145VFEi;VXM155C;VXM-175VFi
    VAG: VWZ;AUZ;SKZ;SEZ
  6. #4805
    May 2024
    Hello. I need help with my Chrysler radio code.
    Type: RB3
    Model: Becker, BE6802
    Serial No: 41050534
    S/N: T00BE223400101
    Supplier: 23780A
  7. #4806
    Dec 2022
    B&H,ŽIVINICE
    Hi. Try code 4392..........
  8. The Following 2 Users Say Thank You to nihad69 For This Useful Post:
    Albert G (26th May, 2024), filipczos (26th May, 2024)
  9. #4807
    May 2024
    Big thanks
  10. #4808
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by filipczos View Post
    Type: RB3
    Serial No: 41050534
    S/N: T00BE223400101
    Supplier: 23780A
    Big thanks
    Hello,
    Code is . . 62111
    Don't forget to press the THANKS & REPUTATION button for help in the future.
    To all NEW OR OLD members seeking help.
    Please check that you said Hello, Hi, or Please.
  11. #4809
    May 2024
    how to enter 9 when the display shows up to 6?
  12. #4810
    Dec 2022
    B&H,ŽIVINICE
    Hi. You have to press the key 3 nine times and you will get the number 9......
  13. The Following User Says Thank You to nihad69 For This Useful Post:
  14. #4811
    Albert G's Avatar
    Apr 2016
    Type: RB3
    Serial No: 41050534
    S/N: T00BE223400101
    Supplier: 23780A
    Big thanks
    Quote Originally Posted by Albert G View Post
    Hello,
    Code is . . 62111
    Code Entry as Follows:
    Switch Radio On - Display Shows
    " Enter Code "
    Enter CODE in the order it is read :
    For Example, to Enter Code 12345
    Press Preset 1 then 2 then 3 then 4 then 5
    The Code will Enter Itself Automatically
  15. The Following 3 Users Say Thank You to Albert G For This Useful Post:
    asliyucegsm (26th May, 2024), diaz38 (26th May, 2024), Laurent33 (26th May, 2024)
  16. #4812
    May 2024
    Quote Originally Posted by nihad69 View Post
    However, the code is incorrect.
    I blocked the radio. :-(
  17. #4813
    May 2024
    This code worked. :-))))
    Thank you very much!!
  18. #4814
    Mhamadnour's Avatar
    Nov 2018
    Hi … Needing code please !!
    TOOBE089572975
    Thank you
  19. #4815
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by Mhamadnour View Post
    Hi … Needing code please !! TOOBE089572975Thank you
    Hello,
    Code is . . 4831
  20. The Following 2 Users Say Thank You to Albert G For This Useful Post:
    Gesha Nemirov (30th May, 2024), Mhamadnour (30th May, 2024)
