Hello Guys , Need immo data to be transferred from ori to donor , here is DONOR flash+eeprom and ORI flash+eeprom
Thanks a lot in advance
Transfer/clone is not possible for this ECU.
VAG immo solutions (clone, immo off, repair) MEDC17, SIMOS, SDI, BCM2, ELV, DQ/DL/VL gearboxes, INVCON, MED9.x crypto
Thanks kuebkfor your reply , i made immo off for the flash , car started but a lot of errors lamps declarations in cluster
Here is the immo_off if you can disable those errors , thanks in advance
Here is a link to download immo_off : https://easyupload.io/q7168w
also i read immo info in both ecu's ;
ORI ECU EDC17C74 IMMO DATA
DONOR ECU EDC17C74 IMMO DATA
if you want you can try my file immo off
Please Press Thanks Button and Reput if i helped !
adosnegoce23 (16th December, 2024)
