Results 1 to 15 of 20
    South Africa
    Default t5 ecu fault delete
    hi there dear members. please if possible remove fault codes from edc17cp20 ecu. 2 liter diesel engine. CAA. P1570 00 Engine Start Blocked by Immobilizer and also - P2563 00 Turbocharger Boost Control Position Sensor Circuit. ecu has been immo off. but showing fault code on dash and also coil light keeps flashing. many thanks in advance keep well.
    Jun 2024
    here you go test it and click tnx and rep no pass
    chs fix also
  3. The Following 2 Users Say Thank You to epr2 For This Useful Post:
    frikki (21st December, 2024)
    South Africa
    Thanks will report back
    South Africa
    hi friend. for some reason after the turbo sensor fault delete car came up fuel sensor fault. if possibe can you please just delete immobilizer fault code. P1570 thanks
    Oct 2023
    VAG EDC17CP20 dtc0ff.rar here don t forget THX+REP
  7. The Following User Says Thank You to bogdy For This Useful Post:
  8. #6
    South Africa
    thanks friend. will report back.
  9. #7
    South Africa
    Quote Originally Posted by bogdy View Post
    hi. can you please correct checsum. k tag shoe checsum error. thanks
  10. #8
    This is dtc off.You need to calculate cheksum by tool.
  11. The Following User Says Thank You to nikka For This Useful Post:
  12. #9
    South Africa
    Quote Originally Posted by nikka View Post
    thanks friend. will try
  13. #10
    South Africa
    friedn i use clone k TAG. k tag dont want to correct checksum. please correct for me. thanks
  14. #11
    This is with cheksum corected.
  15. The Following User Says Thank You to nikka For This Useful Post:
  16. #12
    Oct 2023
  17. The Following User Says Thank You to bogdy For This Useful Post:
  18. #13
    South Africa
    hi friends. there only one fault still coming back causing limb mode. please erase this fault aswell. then im sure car will be 100 percent driving. many thanks for help.
    hi there. just one more fault code afterother faultswere deleted. this one causing limb mode. please if possible remove. thanks you so much.keep well
    5229 - Fuel Rail/System Pressure
    P0088 00 [10100111] - Too High
  19. #14
    Jun 2024
    bro you cannot fix car whit dtc off thats just mask...
  20. The Following User Says Thank You to epr2 For This Useful Post:
  21. #15
    South Africa
    i understand. can you then just remove imo fault code. nothing else. car drives fine. with original file. just coil light flashing because of immo fault in ecu. please just remove immo fault. thanks other stuff are fixed now.
