    Mar 2018
    Romania
    Default Volvo EDC16C34 DPF&EGR Off
    Hi! I need help with Volvo 1.6 EDC16C34 DPF&EGR Off and also MAF sensor OFF (P1320 )
    I tried with Volta solution but after few km , esp on and limit 3000 rpm.
    Thanks!
    adxinnixda's Avatar
    Feb 2023
    End of the world
    Hi, DPF, EGR and Maf DTC switched off. For the password write me in PM after you let me THX and REP. ... THE Maf can be a result from bad EGR
    NO Advertising !!
  3. The Following User Says Thank You to adxinnixda For This Useful Post:
    lovinedi03 (22nd December, 2024)
    Mar 2018
    Romania
    Quote Originally Posted by adxinnixda View Post
    This solution not work. Car limited 3000 rpm always
    adxinnixda's Avatar
    Feb 2023
    End of the world
    I using the same solusion for EGR and DPF actally on volvo v50 1.6 edc16c34 exactly same sw 391798 and its working fine. But i dont have trouble with the MAF like you.
    P.S.: which tool you use? Chceksum is ok? let the egr, diff pressure and temperature sensors all connected
    NO Advertising !!
    Mar 2018
    Romania
    EGR īs blocked and electrical fault,it's neccesary unplug
    Mar 2018
    Romania
    I haven't been able to solve the problem. Can anyone help me with a solution?
