Results 1 to 9 of 9
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    Exclamation Vaux Vectra C diesel starting problem
    just a quick 1 for you lads
    iv had a few vectra diesels in over past months
    they take ages 2 start, they take a long time to kick in
    the first time you start them they are fine but the rest of the day its a hard start
    iv had starter motors checked, glow plugs changed, batterys changed
    still no joy
    its seems like a common problem
    any ideas??
    thanx
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Meat-Head's Avatar
    If this is the ones i think they are, them the injectors are 'in the head'
    the have the leakoff (spill, whatever) pipes, go manky, remove them and replace with fresh, or 3.2mm fuel hose.
    Whilst we are on the subject of bags of crap:
    Has anybody found out why Toyota Previa, Lucifers and Toyota Enema's
    loose the rear side lights for no apparnt rerason, common faul, word on street nbody has found or intreasted in the proper fix.
    Meaty.
    Mar 2010
    west midlands
    the cdti common rail engines mate?
    z786's Avatar
    Aug 2009
    yh i think so
    Mar 2010
    west midlands
    if the cdti common rail - non isuzu engine, you first need to do bottles test on injectors, then check high & low pressure pump delivery pressures, then starter draw tests when hot & cold. a compression test might be the way to go too mate
    Meat-Head's Avatar
    Quote Originally Posted by dafdiagnos View Post
    BUT if it is a taxi, just tell him it's ~~~~ed, he needs a new one
    Mar 2010
    west midlands
    z786's Avatar
    Aug 2009
    cant be doin that 2 the taxis
    i knew it was pointin 2 a compression test, but im very lazy so thort there mite be a "common fault"
    Quote Originally Posted by z786 View Post
    still no joy
    any ideas??
    thanx
    The first time start well,glow plugs ok
    Engine warm ,maybe if you find more rotation to start engine it starts,
    Ground cables,revision on starter even looks ok.
    A second battery connected ground direct to engine to see the diference,
    Rpm sensor clean.
    Each car...each headache
