Results 1 to 10 of 10
Thread: clone edc17CP14
    credoline's Avatar
    Србија
    Default clone edc17CP14
    Hi friends. I need help to clone original ecu 0 281 014 235 Bosch 03L 906 022 B Audi A4 2.0 TDI EDC 17CP14 to donor ecu 0 281 015 823 Bosch 03L 906 022 LS EDC 17CP14. All files are attached.
    Thank you
    Feb 2010
    Bosna
    0 281 014 235 = VW BOSCH EDC 17CP14-3.2
    0 281 015 823= AUDI BOSCH EDC 17CP14-3.4
  3. The Following User Says Thank You to mvekaz For This Useful Post:
    credoline (31st December, 2024)
    credoline's Avatar
    Србија
    What to do with flash ? Rewrite complete from old to new?
    Feb 2010
    Bosna
    Yes, but as you can see your original ECU type is not same as donor. So, maybe it will work, maybe not. Also, you can try to flash frf file in attachment.
  6. The Following User Says Thank You to mvekaz For This Useful Post:
  7. #5
    Smart66's Avatar
    Dec 2020
    All EDC 17 have OTP sector which can't be changed. Old ECU's flash can't be used dirctly on donor ECU's
  8. #6
    Feb 2010
    Bosna
    Yes, this is transfer of immo data (VIN/PIN/CS/MAC) to a donor ECU. So you have to be sure donor unit is 100% compatible with original.
  9. #7
    credoline's Avatar
    Србија
    I know that, but customer found couple of ecu-s, not any was the same numbers and software as original.
    Quote Originally Posted by mvekaz View Post
  10. #8
    Smart66's Avatar
    Dec 2020
    Report results whether it works or not. Sometimes car can start but driving performance is poor
  11. #9
    credoline's Avatar
    Србија
    I am not tried, because flash data layout is not the same regarding OTP data and i can not transfer flash data. And i am give up. Customer will search for another second hand ecu the same ecu as original.
  12. #10
    Sep 2013
    GERMANY
    ok i can make the clone file to start the car
    this clone files have 1kb+ because the software make it
    write first epprom ori in donor and next write this file in flash
