Hybrid View
    Tunisia
    Default Help EWS3 dump corrupted
    Hi all
    I have EWS3 corrupted file, can someone repair it or reset it?
    Jakarta, Indonesia
    Quote Originally Posted by testourii View Post
    Hi all
    you try edit sync to ecu?
    why ?
    Tunisia
    Thank you for your answer
    yes, I tried edit sync to ecu because car didn't start.
    car is all keys lost, I read MCU, program key with ZED-Bull, but no succes , i thought problem is synchronisation,
    Jakarta, Indonesia
    send original dump ews
    Jakarta, Indonesia
    if the previous problem only lost key, sync will not change.
    re-write your original dump before editing
    you try sycn treatment with GT1. maybe this will work, if this is the original dump of the same car.
    you have make key number 8 in your dump.
    if it not crank maybe hardware ews troble. you check it
    regard
    Tunisia
    Thank you bali motor
    I didn't find original dump, i will try with your solution
