Results 1 to 13 of 13
    taourirt morocco
    Default audi navigation plus 8E0035192B need code from dump
    Hello I need to read the Radio code from this radio:
    8E0035192B
    auz1z1
    i read fis as 24c32
    WALES
    Quote Originally Posted by kadeleck View Post
    8E0035192B
    auz1z1
    i read fis as 24c32
    Your code is 0332
    wbr
  3. The Following 8 Users Say Thank You to shooting For This Useful Post:
    076458C (2nd January, 2025), diaz38 (2nd January, 2025), kadeleck (2nd January, 2025), nihad69 (2nd January, 2025), REZON (2nd January, 2025), rutra111 (2nd January, 2025)
    taourirt morocco
    0332 i test it not working
    076458C's Avatar
    Jan 2023
    Try......0699
  6. The Following 3 Users Say Thank You to 076458C For This Useful Post:
    kadeleck (2nd January, 2025), smoggy (3rd January, 2025)
    taourirt morocco
    0699 not working
  8. #6
    Jun 2023
    connect in car code 0332
  9. The Following 4 Users Say Thank You to rutra111 For This Useful Post:
    Albert G (2nd January, 2025), kadeleck (2nd January, 2025), nihad69 (2nd January, 2025), shooting (2nd January, 2025)
  10. #7
    076458C's Avatar
    Jan 2023
    0699 not working
    Then try this one: 0611
    For this dump I can see 3 possible codes:
    FIS 1: 0332
    FIS 1: 0611
    FIS2 : 0699
  11. The Following 3 Users Say Thank You to 076458C For This Useful Post:
    carradio2001 (3rd January, 2025), kadeleck (2nd January, 2025), shooting (3rd January, 2025)
  12. #8
    taourirt morocco
    hello every one
    i test all codes it dosent work after i put another dump that i now the code
    it dosent work too .so i add another wire to vcc then it work .it is my falt .
    excuse me for my bad english.
  13. #9
    WALES
    hello every one
    Use my code IN the car.... it's correct
    wbr
  14. The Following User Says Thank You to shooting For This Useful Post:
  15. #10
    taourirt morocco
    hi.i will try
  16. #11
    Dec 2022
    What do you think if shooting fixes the radio remotely, you can't wait two hours with the radio on to offer you to enter the code!! What gentlemen, everything for free and again it's not worth it!
    You can't put everything on a plate!!
  17. The Following 2 Users Say Thank You to nihad69 For This Useful Post:
    rutra111 (3rd January, 2025), shooting (2nd January, 2025)
  18. #12
    taourirt morocco
    hello shooting.thank you for your help.
    i put my original dump. 0332 not working
    the good code is 0699.
  19. The Following User Says Thank You to kadeleck For This Useful Post:
    076458C (3rd January, 2025)
  20. #13
    WALES
    Yes my mistake, it's FIS2 not FIS1... I should have checked
    wbr
