Results 1 to 9 of 9
    barti122's Avatar
    Poland N
    Default Partner/Berlingo dash dump Jager 908AZ60 need
    I have dash Partner Jader MCU 68HC908AZ60 and not work.
    I have new MCU 908AZ60 but i dont hav dump this dump.
    Please help me and send got dump this dash
    THX
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    Quote Originally Posted by barti122 View Post
    THX
    Hi friend , Usually can damage eeprom of partner and berlingo dash(2j74y)
    But , i am sending full dump for 2j74y.. ( 0 ) kilometer .. you can write this dump with etl hc908
    br
    kasim
  3. The Following User Says Thank You to kasim_izmir For This Useful Post:
    thomasnb (11th October, 2020)
    barti122's Avatar
    Poland N
    THX wery mach
    I tested
    I programmed UPA
    checks the file and it is completely different on the size of 157,886 and the one I have is 1024 kb. May not save as well I think.
    barti122's Avatar
    Poland N
    I have problem with save dump UPA. 1 errors device not found only alle flash. I save eeprom and work , i try save flash and not work??
    for write full memory space on this MCU must use ETL, UPA good only for eeprom area.
    BR
    barti122's Avatar
    Poland N
    Thank you very much for your reply
    argentina
    Default dump 68hc908az60
    hello, Kasim
    I will use the file for you given the forum to attempt a repair on a board that has the file berlingo mcu broken
    Jan 2011
    Quote Originally Posted by kasim_izmir View Post
    br
    kasim
    thanks for the input, very useful
  10. #9
    Jan 2011
    I have problems too with UPA for program this mcu, now for this i use ETL as our partner we suggested previously
