Results 1 to 14 of 14
Thread: starview 5 help
    DK Veteran belfastdaren's Avatar
    Oct 2008
    Default starview 5 help
    when i have done a factory reset choose english as my language then scanned for channels this reaches 100% then it goes to manual scan if i exit everything after it has finished it takes me back to the choose my language screen which i cant get out of seems to be a continous loop with me not being able to exit
    thanks for any help
    satsmo's Avatar
    Jun 2008
    Power the box down from the main switch on the back for a minute and then power back up again.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
    Oct 2008
    Default :-(
    still no joy stuyck in this endless loop
    satsmo's Avatar
    Jun 2008
    In the CAS menu, where you see keycode, press default key and try it again. If that fails try a factory reset, rescan and turn keycode back on.
    Oct 2008
    Default have
    have done the above
    satsmo's Avatar
    Jun 2008
    A reflash with V2.03 Digital Kaos - Downloads - TheboxSuperUSB2_v2.03.20090923.BIN should solve the problem but I have seen it sorted before by leaving the box off for a while.
    Oct 2008
    Default ty
    ty m8 i will leave my box off overnight and check in the morn, i will post back to let you know the result
    Nov 2008
    any joy darren?
    i'm in belfast and i'm having the exact same problem with my sv4
    Oct 2008
    Default nope
    no joy with reinstalling firmware ( i tried on a different star view 4 as well )
    what can virgin have done ?
    Oct 2008
    Default fixed
    i rescanned using the chorus settling instead of ntl and all back working :-)
    Default having same problem wth brothers sv3
    me and my brother both have sv3, we both lost some channels and did a factory reset turned on emu, then automatic scan, mine is working as usaul but his wont pick up any channels when scanning and is stuck in menu
    Oct 2008
    Default might work for you
    try scanning chorus instead of ntl that worked for me
  13. #13
    satsmo's Avatar
    Jun 2008
    Strange indeed as they use 6875 as an SR as opposed to 6887 for N.I.
    I know that cards are at the moment been issued in your area and that VM are aligning networks but glad it has worked out for you. Hopefully you will get a while longer.
  14. #14
    cheers worked on chorus
