Results 1 to 15 of 15
    Jan 2024
    Default pls help astra j dash ---------
    i just swape bcm to test something now i put back ori bcm from the car on the dash have -------- a read dash memory 95080 inside i see vin i s corect iand pin is corect from the car can someone help vin from the car is w0lpe6eg3a8014548 pin is 6513 tnx
    Jul 2014
    Quote Originally Posted by avosoft View Post
    hi, post the bcm file here
    Cheers
  3. The Following User Says Thank You to auto80 For This Useful Post:
    avosoft (23rd January, 2025)
    Codekuba's Avatar
    Aug 2018
    Dump from your dash is ok.....
    Post dump from ori bcm
    What dtc fault in bcm and ic???
    HELP == thanks + reputation
  5. The Following User Says Thank You to Codekuba For This Useful Post:
  6. #4
    rafal's Avatar
    UK - PL
    I will put in one's pennyworth
    Even dump looks ok, don't need work ok
    I had same situation with meriva b
    I changed for other one dump + edit to my car and all went ok
    Now the best option will be to find dump from same dash , edit vin ,pin etc and test
    try this dump - if problem still - then pos bcm file as friends posted above
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following 4 Users Say Thank You to rafal For This Useful Post:
    auto80 (23rd January, 2025), avosoft (23rd January, 2025), brend (24th January, 2025)
  8. #5
    Jan 2024
    hi friend it is the same i read bcm 24c16 inside can someone check tnx don.t have errors on diagnostic
  9. #6
    Jul 2014
    hi, try this and report
    Cheers
  10. The Following 4 Users Say Thank You to auto80 For This Useful Post:
    avosoft (23rd January, 2025), rafal (23rd January, 2025)
  11. #7
    Jan 2024
    it isame friend still have ------ on instrument
  12. #8
    Jul 2014
    hi, try also this and report
    Cheers
  13. The Following User Says Thank You to auto80 For This Useful Post:
  14. #9
    Jan 2024
    it is same
  15. #10
    rafal's Avatar
    UK - PL
    it is same
    try to drive car some km...............and check
    need help
    who will help?
  16. The Following 2 Users Say Thank You to rafal For This Useful Post:
  17. #11
    Jan 2024
    i will try
  18. #12
    Jan 2024
    i drive 15km it is the same(
  19. #13
    rafal's Avatar
    UK - PL
    strange situation
    all yours files looks ok..............
    need help
    who will help?
  20. The Following User Says Thank You to rafal For This Useful Post:
  21. #14
    Jan 2024
    don.t understed vin same pin same but still have ------ on dash
  22. #15
    Jan 2024
    i found dash dump change vin and pin now is ok just dump is from automatic car and say transmision not ok on display maybe someone have dash dump from manuel car tnx friend
  23. The Following User Says Thank You to avosoft For This Useful Post:
    dashradio (23rd January, 2025)
