Page 5 of 5 FirstFirst 12345
Results 61 to 68 of 68
  1. #61
    antonnio_stef's Avatar
    romania
    [QUOTE=bram380;1524813]Write sweeper 03.hex to mcu ATtiny 2313.
    Write EPROM.bin to eprom 28f512 for ecu application.
    sorry but i dont understand. whend i need to write eeprom.bin? in what
    u mean if i use aplication "ecu decoder" with pc with max232 i use eeprom.bin ?
    i will use only tiny sweeper , i need put some where that eeprom.bin when i decode ecu from list ?
  2. #62
    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    there is other metod to make immo off this ecu-s.
    In DK use search and you will find .
    Large nations behave like gangsters ,and young as prostitutes !
  3. #63
    romania
    i finish my tiny sweeper , i write mcu tiny with sweeper.hex and i lock the bits ..
    when i powered led is blink intermitent continuously. its ok ?
    whend she stop blinking? after i succeed remove immo?
  4. #64
    GB
    I think the sweeper0.3.hex must be write in flash of attiny2313 and Eeprom.bin must be write in Eeprom
    of Attiny2313.
  5. #65
    romania
    thanks.. but let hear another advice..
    anyone ? please
  6. #66
    Hi friends, where is the correct way for program attiny2313 with progisp?
    Thanks in advance friend...
  7. #67
    all2trash's Avatar
    Jun 2009
    naboo
    Hi Antonio, I've lost 2 days figuring out how to make the sweeper to work. I've also got the blinking LED at the beginning. Follow these steps (tested, working):
    Write sweeper 03.hex in the following way (with PonyProg):
    (1) first select device Attiny2313
    (2) second write the fuse bits, and verify them
    (3) from the menu "open device file" -> select "sweeper 03.hex"
    (4) from the menu "write all"
    (5) DO NOT PERFORM VERIFY OR READ OPERATION, just
    remove the chip from the programmer.Othervise you will have
    blinking LED
  8. The Following 3 Users Say Thank You to all2trash For This Useful Post:
    eric paris (10th November, 2017), satesquio (17th November, 2015), visio (18th October, 2017)
  9. #68
    Jul 2020
    good afternoon,my question -is necessary to have ECU hooked up on car,or I can work it on a bench with powersuppluy.
    I read that using sweeper for megane '97 is necessary have ECU connected always on a car.Thanx for reply.
