Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 68
  1. #16
    Jul 2010
    west mids, uk
    ?????EBAY-RULES??????
    wasnt aware they applied here!!
    Anyway, prob just stick to coding a new key rather than lifting pins on these, wrecked a few already!!
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  2. #17
    Meat-Head's Avatar
    Quote Originally Posted by ninja123 View Post
    Sorry my bad Inglish/Emerican.
    What i meant was if you contact a seller on ebay about something, you and they can loose your account
    Meat.
  3. #18
    i_shot_the_sheriff's Avatar
    Nov 2008
    I've tried over 20 times to sweep ecus with this "shit" :O !! It's not working
    But...
    A friend of mine told me that this sweeper works only if the ecu is connected to the car!! He tried it and he did it!
    I can't try it because i dont have a usb converter :P i will buy one and i will try
  4. #19
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by p0z3r View Post
    But...
    You must have patience, some times 20 times is not enough. You must luck at the MIL. First power up the ecu, you eill see MIL blinking, next connect the sweepre, the mill must steady light then pres sweep button. After the cycle has finished power off the the ecu and power it again on without sweeper and see if mil is lighting steady. If not try again until the job is done.
  5. #20
    Nov 2008
    Well, i forgot to mention that i didn't buy this sweeper from tektronics but from an Italian guy on facebook! There is no sweep button! You send the signal(frequency) via the software!
  6. #21
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    Quote Originally Posted by Meat-Head View Post
    must admit, but against ebay rules , when get round to it, find somebody that is breaking that car, get them to cut off multiplug off ecu - not like anybody needs one!
    as for lifting pin, you can SOMETIMES hammer a hole through the board away from chip and resolder later - scary this pin lifting lark!
    Meat
    Have got these harness plugs already from breaker yard.
    Problem i i foocked up three fenix 5 ecu's in the last two weeks by removing the chip .
    Would like to know what is best tool to invest money into so that i do not blow the next one again.
    Got car eventually to run with the tweeser method . ( Without need to remove chip)
    So seems tiny sweeper is maybe not a good choice..
    Thanks..
  7. #22
    Romania
    Quote Originally Posted by PierreTheron View Post
    Thanks..
    But there is a better method, without open the ecu, but it is time consuming method. Search renault decoder here on DK
  8. #23
    Aug 2009
    Quote Originally Posted by tehnosoftex View Post
    Tried to built one of these long time back. Left it clicking for days on an ecu and gave up on it..
    Maybe better to buy one.
    Will have a look into that again.
    Seems safer option..
  9. #24
    miha99's Avatar
    Sep 2009
    EU
    @PierreTheron I use for fenix always tiny sweeper (I founf it here on DK) I always solve problem (immo off) on car (only cut immo line) open ecu and connect sweeper on appropriate pin on flash and with this metode bypass immo on more than 20 ecus with 100% success.I spend for hole operation only 5-10 min.
  10. The Following 3 Users Say Thank You to miha99 For This Useful Post:
    eric paris (7th November, 2017), satesquio (17th November, 2015), Stahab (9th October, 2020)
  11. #25
    Nov 2008
    I've tried over 5 times with the ecu on the car but still nothing!
    Do i have to cut the immo pin? By the way... i have the immo box off!!
    (on a Peugeot 106)
  12. #26
    Top Poster + andy99's Avatar
    Aug 2009
    EUROPA
    Quote Originally Posted by miha99 View Post
    I assembled it and does not work
    I programmed a peak with Beeprog +
  13. #27
    micromax's Avatar
    Dec 2009
    South Poland
  14. #28
    Meat-Head's Avatar
    ~~~~ making one, ?25 is, you can download off greebid.com
    TMS374 ECU Decoder
    no idea if it works, but small enough to fit in your man bag
  15. #29
    Aug 2009
    EUROPA
    Quote Originally Posted by micromax View Post
    yes i used it but dont work
    my lock bit fuse is
  16. #30
    omglol's Avatar
    Jan 2009
    Europe
    For TMS based ECUs the best method I have tested so far is the tweezer method. Don't need any software/hardware, just cut the immo line, open ecu, remove gum from flash and run tweeters over pins with ignition ON ... job done in 15 min max.
