The title explains it all. Should I remove dpf then write the dpf off file or vice versa? Whats the difference and what are the problems that you can face.
Does not matter, just don't drive to much with dpf off file if the dpf is not removed
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
VAGBMW (25th January, 2025)
Thanks a lot bro. Can you do me a favor and check if this file has dpf and egr disabled?
Car: Seat Altea 2008 1.9 TDI 77kw
ECU: edc16u31/34
File read with kess v2 clone from obd port
This is the car I just bought and it has black smoke a little bit when I accelerate. I guess they disabled the egr and dpf not sure tho. Thanks for helping again
Thanks brother. Sorry for asking too many question I have one last question, how do you find the dpf switch on winols on edc16u34 ecus? I'm new in this stuff and really want to get into tuning in the future
