Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 98
  1. #16
    Quote Originally Posted by doslamer View Post
    i have the same problem and i fix a little bit, but i think that my software is confused because i connect to 'vw beetle' and read some data but nothing else can do ?!?!?!
    first of all change the black cable, original cable pin outs is not correct, when i switch to the car after 3-5 minute my blue box start heating very much, after changing of the black cable everything is ok. i make cable by myself(first i call and ask the provider for pin outs) here it is :
    rs232(com) obd
    1 ----------------------16
    2 ----------------------7
    3 ----------------------14
    4 ----------------------6
    5 ----------------------4 and 5
    pin 2 of RS232 is switched ONLY to pin 7 of obd.
    now i can connect to cars without a problem but can't do many thins.
    if somebody can tell that maybe my software is installed wrong.
    any advice will be help full.
    hello, I received the second vagdash k+can from china.
    this one has the folowing configuration:
    rs232(com) ---------- obd
    2 ----------------------7 and 8
    6,7,8,9 ------------- not connected
    tomorow I'll test it and will post result
    best regards to all
    Software Installation
    1. uninstall the vagdash software first if you installed it before
    2. connect the vagdash cable with the computer
    3. install driver first. make sure select USB port, NOT COM port!
    4. then install the software
    5. connect to car.
    6. start software
  2. #17
    Member Flash_chip's Avatar
    Quote Originally Posted by cosmind View Post
    best regards to all
    5. connect to car.
    6. start software
    Hello Cosmind,
    I await your results and hopefully it will work this time
    Good luck
  3. #18
    I dont found any car with edc16. must to wait.
    I will post result soon
    regards
  4. #19
    Hello again. I tested vagdash k+can 4.22 on Skoda II
    changed km on EDC16 and all it's OK.
  5. #20
    Austria
    Did you maybe tried newer version with v5.05 inf you have? 5.11 ?
  6. #21
    Quote Originally Posted by oep View Post
    I'm interested also to know
  7. #22
    Germany
    Hello . I tested vagdash k+can 5.05 on VW Touran
    changed km on EDC16 on Tacho and all it's OK.
    Video attached. RapidShare: 1-CLICK Web hosting - Easy Filehosting
  8. #23
    USA
    hi 16eddi67,
    which interface did you use with 5.05 software and where did you get it?
    thanks...
  9. #24
    z786's Avatar
    10 Steps Ahead of You
    im sorry mate but i didnt see you change the km in edc16, you just read the chip??
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  10. #25
    bron
    merci a vous pour vos reponses
  11. #26
    Germany
    Quote Originally Posted by RCS View Post
    hi 16eddi67,
    thanks...
    Hi,RCS CS VAG Dashcom+can V5.05,
    Hi, Z746 Reads and writes
  12. #27
    Austria
    Quote Originally Posted by 16eddi67 View Post
    its same product same clone, from ecu_tool, auto_km_factory and others..
    ps: for members which claim they have clone working ok, no problem, please post pics both side pcb so we compare it's not china. if possible..
  13. #28
    you had the opportunity to test it on an Audi A4 RB8?
    your link "RapidShare" does not work!
  14. #29
    Germany
    Quote Originally Posted by Flash_chip View Post
    Hi,video Attached
  15. #30
    Usa
    Hello to everybody. i use 5.11 software, but i think that is important to know if you upgrade the box with 5.11 you can not downgrade to old one, because the software make firmware upgrade to the box. i make my black cable like COSMIND write
    and i hope to came in my garage some car to try what i can do with my blue box. Next week i will post my result.
