Results 1 to 5 of 5
    Default audi a4 2005 dash swap
    Audi a4 2005 2.0 tdi. Dash is dead, on ACC only esp and airbag light, not start.
    Dash is 8E0 920 900R bosch. New dash with same numbers works ok, but need to code to car. Tried to write ori dump 24c08, but got DEF and ERROR on display. Is it possible to transfer data from dumps?
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    VAG EEPROM Programmer 1.19g + k-line adapter
    eprom is encrypted and linked to the MCU, done only via obd2
    I tried VAG eeprom programmer 1.19 - starts to read and stop with message 'can't read blocked area' or something like that.
    Few month ago I had same situation with similar rb8 dash, but this 8E0 920 900R is different.
    Oct 2020
    Bulgaria
    You need better tool. Carprog clone minimal
  5. The Following User Says Thank You to evgeny87 For This Useful Post:
    drz (31st January, 2025)
    Solved with xtool, but tried carprog too - you were right, it can read/write immo data. Thanks
