Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 110
  1. #16
    Feb 2025
    Do I have to copy the code in “autocom” or in “SuperActivator”?
    SuperActivator : ZMOiXmjndUqUqUlEY6vYnIQcolC1m94zRjsZIzHWcL_eQ
    autocom: ivwQUvMxPC_0o4kD25eQaiIF3X1BLGVj-szuxlifVz0
    sorry for the ignorance, i need help. i already copied it using control+c and paste control+v
  2. #17
    Feb 2025
    autocom:
  3. #18
    Aug 2020
    Quote Originally Posted by Yisus View Post
    No problem man, copy this code to the superactivator. Remove any spaces you see in the code
    V2sxUGFWaHRhbTVrVlhGVmNWVnNSVmsyZGxsdVNWRmpiMnhETV cwNU5IcFNhbk5hU1hwSVYyTk1YMlZSXFdXbHpkWE1nTFNCa2FX ZHBkR0ZzTFd0aGIzTXVZMjh1ZFdzPVxxSEJyRVFINDVERU5NQ1 k3U21WbWg4ZlpONUNEZ0t1T3FnWW5PYi9iY25SdVpmZ05HTmNC T2xUdERpZmNKZjJKbjZNczlhV1lLOWZoejFBczl5bXJZTkVnYm MvQklUNzV5aWlQRndTd3VldEN5Zm1BanI5VGVUVnFuQVczc1BH R3ZzL2NUd2pMTTY4YmxycFhwemd0NDJDSEpScUw0ZzZLY2pCVl VoZnJGSmc9XGlGQk9KVGZLMXdnZEJCTVphVmtidk92Kw==
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  4. #19
    Feb 2025
    ¿Tengo que copiar el código en “autocom” o en “SuperActivator”?
    autocom:
    perdón por la ignorancia, necesito ayuda. Ya lo copié usando control+c y pegué control+v
  5. #20
    Feb 2025
    I have removed all the spaces from the code you gave me and copied it into the “SuperActivator” but it doesn't work, I thank you for your time but I will try to install the Autocom 2021.11 from the other post to see if I have more luck, thanks for everything.
  6. #21
    Aug 2020
    Strange, the code is correct for the 24th feb. You can download the 2021 and activator from the tool anyway
  7. #22
    Feb 2025
    I have the pc with a different date, is that the problem?
  8. #23
    Aug 2020
    Yes, there is only one correct code per day, change to the 24th and activate. You can change date again after activating. I am still in the 24th
  9. #24
    Feb 2025
    i reset to the current date, tried the codes in both autocom car and super activator and they don't work. here i will try the 2021 version.
    there are no instructions or steps to follow?
  10. #25
    Aug 2020
    Its the same thing, copy the code from software to the activator to generate the activation code. Select 1622 firmware if you have double pcb vci or 3201 if you have single pcb vci
  11. #26
    Jan 2025
    i cant download, i have unsufficient permisions. Can someone help me and email me so we can arrange file transfer for keygen
    my mail is milovic.m.ftn@gmail.com
  12. #27
    Aug 2020
    Quote Originally Posted by marko123321 View Post
    Read the forum rules, it tells you what to do if you cannot download
  13. #28
    Mar 2025
    Can I use this software on any other windows than win 8?
  14. #29
    Aug 2020
    Quote Originally Posted by celavac View Post
    Should work on windows 7, 8, 10 and 11. Adding antivirus exceptions on windows 7 does not work
  15. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    celavac (4th March, 2025)
  16. #30
    Mar 2025
    Hello, can you guys help me out, the keygen is driving me nuts. Delphi 2021.10b Cars
    thank you in advance.
