Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    drakov's Avatar
    Aug 2008
    Default Help with Fiat Bravo Airbag
    FIAT BRAVO 2008 MOTOR 1,9 JTD 150 CP
    EEPROM ATMEL 25320
    MODUL AIRBAG SIEMENS-VDO 5WK43641
    Need the attached dump cleared if anyone can help, it's for a good friend of mine.
    Thanks in advance
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by drakov View Post
    EEPROM ATMEL 25320
    Thanks in advance
    Hi.
    Try this two dumps,one of them should work.
    Write back if it works.
    Dump not tested.
    Password is in your PM
    Best regards.
    hello
    can i have the pass to compare the data? i have a bravo airbag module pn. 51775402 5WK43640 eeprom 95320 need to clear crash, or someone can help me clear crash? thks in advance
    the module is make by siemens
    any help please?
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by weltune View Post
    any help please?
    Hi.
    Good luck.
    Dump is read wrong.
    By this eeprom space dump is to big.
    Line 1000 can not be.
    Best Regards.
    crash dump attached readed attached
    juozas10's Avatar
    Jan 2010
    LT
    Hi.
    Try this two dumps... one of them should work. Write back if it works.
    Password is in your PM.
    Best regards.
  9. The Following User Says Thank You to juozas10 For This Useful Post:
    checkservic (29th November, 2022)
  10. #9
  11. #10
    Dec 2009
    Default 5WK43640
    Please help. I need cleare crash data.
    File in attachment
    Fiat bravo
    Airbag
    5WK43640 51775402
    EEprom 25c320
    Siemens VDO
    Cpu TMS470 980
  12. #11
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by pandora6 View Post
    File in attachment
    Hi.
    Please write full ECU discription.
    Best regards.
  13. #12
    juozas10's Avatar
    Jan 2010
    LT
    File in attachment
    Fiat bravo
    Airbag
    5WK43640 51775402
    EEprom 25c320
    Siemens VDO
    Cpu TMS470 980
    Hi.
    Crash data was cleared.
    Please report.
    Pass.P.M.
    Best regards
  14. #13
    Jul 2010
    turkey
    Default help
    Quote Originally Posted by juozas10 View Post
    Hi.
    Best regards.
    password please
    thanks .
  15. #14
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by seyyid airbag View Post
    password please
    thanks .
    Hi.
    Please post your the original crash dump
    Best regards.
  16. #15
    Jan 2010
    greece
    hello any help VDO 5WK43640 51775402 FIAT BRAVO 95320 thanks
