Try using telnet in windows or putty to telnet. type in username and pass then type in passwd to enter new password
Thanks but tried puttytel also and still get the same message 'Login Incorrect'
Any more ideas?
Thanks in advance
Looks like someone's already changed your root password.
You can reset your dreambox password using dreambox remote:
1.install tuxbox commander using addons button
2. Start tuxboxcomander
3.go to in /var/etc/ and open the file passwd
4.press 4 on remote to go into edit mode.
The first line is root:*****:0:0:root:/home/root:/bin/sh
where the ****** delete it (by using remote arrows to move cursor right and then pressing volume minus)
delete *** until upto :0:0:root
and press ok and exit -> save
the first line should look like this after the edit
root::0:0:root:/home/root:/bin/sh
then login with user root and password leave empty
you could telnet and change the empty password with your own so known can easily hack into your dm box.
Thanks ever so much for this but, when I get to add ons, I'm guessing that I select 'manual install' and then go to 'var' I can see a folder called 'tuxbox' with 3 more folders inside it called 'config' 'plugins' and 'scce'
I don't know what to do next.?
Thanks in advance
hi im new to this dm fourm can some one help me with login to dm500 i dont hav a passwd for it
ps i cant delete the passwrd mentioned above
also I set up drmbx to TV and all I can get is " no signal " the remote wont even work the box , unable to get red or green light with remote , reboot many times but only thing it says is " no signal "
going back over my steps , I clicked on "erase entire flash without Bmon" thinking I had to , to flash new IP, can that be rectified ??
