    Oct 2017
    Suceava
    Default Renault Trafic 2023 gateway bypass
    Hello, i have this trafic 2023 and i want to modify mileage with smok but i cannot pass gateway!
    Gateway is GW 8CH
    284Y66LA7B
    First 100 years is heavyer...
    Autel has that option but have to buy "tokens" on renault server with active account and then you can do it.
    Any other way i don;t know.
    Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
  3. The Following User Says Thank You to atd For This Useful Post:
    mihaiti (4th February, 2025)
    rafal's Avatar
    UK - PL
    bypasss possible exatly same as FCA cars
    use search for bypass extension cable
    need help
    now my goal is to buy xp-005
    who will help?
  5. The Following User Says Thank You to rafal For This Useful Post:
  6. #4
    Feb 2025
    france
    Hello, I tried with the BYPASS cable to bypass the GATEWAY but the KM come back
    Mar 2020
    Italia Emilia Romagna
    it is possible to put on bench the dash and after try to modify the km ?
  8. #6
    Jun 2013
    Lithuania
    For these I usually bypass sgw, by probing CAN bus wires at cluster connector (use small back probe needles) and connect them to my OBD breakout box. I can connect to ECM and other modules. Wires are easy to identify (twisted pair), with scope easy to check or wiring diagram.
  9. The Following User Says Thank You to Milicija For This Useful Post:
    adrianojeminaj9 (22nd April, 2025)
