Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
  1. #31
    Member jasonk's Avatar
    Ireland
    Quote Originally Posted by gejzaslapka View Post
    Already from te first TDI engine with code 1Z is regulating valve pulsing with frequency 0,5Hz. You can hear it after several seconds after start. Have You regulating valve as first or second valve? On one pin of valve must be 12V, second pin is grounded from ecu.
    GS
    its the second picture
  2. #32
    gejzaslapka's Avatar
    somewhere over the rainbow
    When this valve is closed turbocharger operates as normally at full power. Have you tried if the turbocharger is partially seizing?
  3. #33
    Ireland
    the turbo looks fine no oil no shaft play and even parked if you rev it up to 4500 or 5000rpm the intercooler pipes wound be solid so there iss good boost its like its just not going into the engine
  4. #34
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by jasonk View Post
    Or not getting out, as I said, check the cats not blocked. Always check the turbo boost under load,
    the reading you get when holding the engine at 3000 rpm with the car stationary is going to be totally different from the reading you get when driving the car, get it to about 2800 in a higher gear then boot it, that’s when the turbo really comes into play
  5. #35
    Ireland
    Quote Originally Posted by Liteace View Post
    I will do mate tanks
  6. #36
    Error code 01262 means clear electric fault. Have you tried to replace the valve?
  7. #37
    "Originally Posted by Liteace
    I will do mate tanks"
    when make turbo pressure measurement,see map and other values to see if anything wrong ( car running...)
  8. #38
    Ireland
    Hi i put on a new valve
  9. #39
    Ireland
    Thanks to everyone for all the help i stripped back the loom all the way to the ecu and replaced the wire from the ecu right back to the valce cleared the fault and were going no problem its wierd because contuinity in the wire was grand
    Regards jason
