Results 1 to 4 of 4
    Feb 2025
    Default Can someone share RX-7 dash script?
    I am after this file in particular to test: RX-7 93C56 km.cal
    Thank you
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by St0RM53 View Post
    Thank you
    What kind of algo?
    Dash Manufacturer?
    Sample file if possible.
    Some info..
    People here cannot Guess what you want
    Edit:
    I Think this is the one you need, Just a Guess.....
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  3. The Following 2 Users Say Thank You to hcip For This Useful Post:
    hoangtu (9th March, 2025), winaiservice (13th February, 2025)
    Feb 2025
    Didn't i wrote enough info?
    Millage calculation algorithm
    Mazda FD3S 1992-2002 RX-7
    There is only one private working calculator i found, it's a script in the ETSmart i believe, search "RX-7 93C56 km.cal"
    I've paid a seller for the new calculation since i lost much time already on this, but would like to know if it's available somewhere. This one works but it's not accurate calculation (92061 instead of 92214km)
    pic is from seller, bin included
    also your scripts not working on this
    • File Type: rar 1.rar (112 Bytes, 7 views)
    Oct 2024
    Most script will not give you the exact mileage. After getting a proximate one and then you can use a sine wave to simulate speedo sensor to change it to exact what you want.
