Results 1 to 4 of 4
    Jan 2023
    Default Land Rover Defender 2024 add key
    customer asked for a new spare key so we removed kvm then replaced the Mcu chip with virgin one. then weprogrammed on bench and then with obd, but last process didnt happen to try and add the new keys. kept loosing communication. any help? thanks
    Dec 2024
    Quote Originally Posted by Mihran Guez View Post
    customer asked for a new spare key so we removed kvm then replaced the Mcu chip with virgin one. then weprogrammed on bench and then with obd, but last process didnt happen to try and add the new keys. kept loosing communication. any help? thanks Geometry Dash
    Scan the CAN Bus system for faults—if there’s a network issue, it could be preventing communication.
    fred77's Avatar
    Jun 2019
    Bull Shite, you'll need dealer tool and new/virgin bcm as locked
    i had a number of disc sports 20-21 reg to play with and autel, acdp and hex-jlr all crap
    And yours is latest ecus so really no chance
    hex-jlr big con the salesmen Gary Lau will only answer tech support once
    You could try Pluto maybe
    eitherway spend £££
    BTW dealer charge £1000+ for new set of keys and ecus
    Solidarity with Ukraine
  4. The Following User Says Thank You to fred77 For This Useful Post:
    qwojtus (28th February, 2025)
    Oct 2024
    Pluto will not do anything newer than 2023.
    As_Built data is too new on your vehicle.
    Main Dealer Tool only.
