Results 1 to 9 of 9
    Nov 2024
    SERBIA
    Default SKODA FABIA DCM 3.7 PROBLEM
    Question for expirience. My friend read flash with flex on skoda fabia 2011 1.2 by obd and done some dtc off. In midle of writing he collaps and dont write flash to the end. After that car dont even cranking. Tryed write original back car crancing but not starting. Message he gets now is ecu blocked plus now diagnostic cant see SN and WIN
    Can it be fixed and how ???? Some ideas maybe ?
    sdtsedat's Avatar
    Jan 2015
    Belgium
    do you have communication with the ecu? Can you make id or you have acces with your tool to engine? (ecu)
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  3. The Following User Says Thank You to sdtsedat For This Useful Post:
    mALOzLO (14th February, 2025)
    Nov 2024
    SERBIA
    Id now working, obd eleven read codes but dont regonize sn and vin numbers. Car cranking but not starting.
    Nov 2024
    SERBIA
    Even tryed update map on last version, not working too
    sdtsedat's Avatar
    Jan 2015
    Belgium
    what tool do you have? Do you have odis or vag can pro?
    Sedat Garip
    Belgium
    With Kind Regards,
    sdtsedat's Avatar
    Jan 2015
    Belgium
    after update did you do disconnect battery 10min and try to start?
    Sedat Garip
    Belgium
    With Kind Regards,
    Nov 2024
    SERBIA
    Didnt try after update 10 minuts without battery, and not me, my friend use flex slave
    Apr 2023
    Salut vous pouver faire une mise a jour avec autotuner tous va etre normale
  10. The Following User Says Thank You to riadh1909 For This Useful Post:
    mALOzLO (16th February, 2025)
  11. #9
    Nov 2024
    SERBIA
    We dont have autotuner only flex slave, ktag china and mpps v21
