Hi all!
I have problem with my galletto 1260,golf 2002 tdi, ATD
it cant read the ecu,nothing happens.I'm not sure how to install the driver.just simply click on the FTDIUNIN.EXE?
Anyone can help?
Hi all!
Anyone can help?
That un installs ftdi drivers...
I have similar problems but have installed drivers correctly.
getting the 4.5 sec load issue on the kmp2000 help :S
Hello
I have same problem when trying to read sharan 2.0 TDI 140 with edc16 u31/34 ecu using galletto 1260.
Will not read at all.
Any help would be appreciated
Have this same problem with a 1260 lead and 1.8t ecu.....
Hi to all on this lovely forum.I'm totally new to this chip tuning thing.I recently bought a 2006 VW Golf 5 2.0L FSi 16V and found that the speed was limited to 200Km/h.I was told this could be removed via a chip tune.Read on some other forums and was suggested a Galletto cable which could do this.After ordering it (one with the LED) from a chinese supplier, I came across this forum and realised that it would probably not work.Tried it and true to many user got the wakeup error.I've also tried it with a 2002 Jetta 1.9 TDi.Same error, though it takes much longer.Just want to know if anyone has managed to solve these problems with this chinese clone.Any help would be appreciated.Thanks in advance.
chinese clone is a piece of crap ... it's really risky to do any ecu with this hardware ... even simple edc15 ...
do you think that somethig which cost 20 euro can do the same job as hardware for 3000 euro ... think
why can t download?
Yes. 100%.
A good cloned tool can be as good as ori one,the dump has to be with no errors,and the pcb has to be with no solder errors,and you can work as good as original one,you dont have update...you dont have any support,this is thrue.
But from HW alone,clone will not always say"shit"
believe me,also big tuners have troubles with original interfaces,or producers themself.
Freezed ecus from VW,i receive dayli,by original vw sw update and freeze for them,this ecu is brocken,for me it s just fine.
If your tool have troubles,or created some trouble,you need support,maybee an bdm and a paralell programmer,so nobody will see you had problems.
This is professionalism,not have 25000$ of ori interfaces,edit soft and nice shop.
Professionalism,is something you learn by time also by errors,and maybee by errors due to a cloned tool.
But,after...you have always more experiance.
Your golf 5 cant be done by galetto clone,you need a can bus flasher like cmd clone.
For the 2002 jetta,try remove fuse for dash,and try again.
Galetto is most sold cloned tool,and i know it works fine for lot of poeple.
But always be aware. Do you have solder skills? If not dont try reflash you ecu with serial programmer( obd flasher ),
if writing fails,your ecu i death,as you cant remove flash and rewrite on paralell programmer
Hi all,
Also having problems acessing Golf V
ERROR SK2
Waiting to see this solved by the masters.
Cheersss
