hy. i`m tring to write a edc16u1 (golf 5 bkc) on the table... the reading it`s ok... but it won`t write.... why?
There are several sites with bunch of tuned files, search the internet. Beware that according to some pro tuners on DK, the tuned files are crap!!! I would not use unknown tuned file on any car..
Make your own tune if you know how, otherwise it will be cheaper to give money to your local pro tuner instead of damaging your car with badly tuned map.. choice is yours..
i did many cars... but no edc16... i`ve heard e need to disable the immo ma program them on the bench....
I've done my altea xl 1.9tdi with edc16u34, I used the driver golf5 , and goes ok. i've reprogrammed several times with galletto clon .
i was the immo.... disabled and worked fine on the bench...
from what I read you can flash ecu using galletto with cars built from december '99, for older ones the ecu will not boot. and for sirrius ecu I heard it works with galletto that has red label on it, I have a friend who sells many of these, I think I'll ask him to take some pictures so we can see the differences.
by the way mine also doesnt read/write sirrius but worked ok on edc15 and edc16, only once i needed to pull a fuse on a vw bora
Hi All,
Any ideas where I can get drivers which work with windows7?
TIA
When i'm trying to read vag cars, i get changing speed error. Also there is a window showing up something with a soldering job (k-line???)..
Can someone tell something more about this?
Thanks.
I found out that Galletto cant read certain EDC16C8 ECUs in Alfa Romeo multi-jet diesels.
I think the problematic are the first series made in 2003. They all have HW number 0281010455.
Any way around that problem?
I read on some Italian forum that this is a well known problem for Galletto 1250/1260. And some people suggested that you can find any original file from that ECU online and write it on any ECU and it will work without any problem, because somehow writing works...
Somehow this doesent seem like a good idea to me? Or does the flash tool only rewrite the parts of ECU that contains maps, and everything else is left as is?
guys i have a Question does the kwp2000+ and the Galleto 1260 Flash the Airbag Crash files????
