@Citronel , so which device does clear the Crash data of the Airbag??
@Citronel well i had a Kia Cerato 2011 and the Technical guy took the ECU of the airbag from me finished it and then got it back to me cleared, so i opened the ECU to check if he unsolderd the Eprom and found that he didnt unsoldered it or remove anything so how come he clear it... also put in mind that the Eprom of the Airbag Module is small one that can't use the DIP clip with it so you have to unsoldered by all means if you want to read it or flash it. so any idea how did he manage to clear it.
Of course he didnt want to tell me.
Also same guy had his laptop with him and he just connect it directly with a cable to OBD of Mitsubishi Montero copied its Software of the ECU to write it on another different Mitsubishi car same way and it the car ran smoothly so is that Galleto or KWP2000??
I'm trying to read a VW Caddy 1.9 2000 with galletto, but I'm getting change speed error? Also pulled out fuse 11, same thing..
Whats wrong? Ssangyong read and writes perfectly... (so the cable is not broken...).
I'm sorry to resurrect an old topic but I get an "Changing speed error" with my 1250 clone.
The clone HAS worked previous year but I forgot how to make it function properly (only used it once...)
Can anyone help me out?
I hate double posting but a few experts have allready awnsered in this topic..
So the change is quit big they get a reply notification on this message :P
Can you check out topic:
http://www.digital-kaos.co.uk/forums...-error-194089/
there it's all explained (set-up, software, drivers etc.)
Thanks all!
Hello everyone!
I have some troubles with BMW 320i MS43 ECU.
I'm trying to use for the first time, Galletto 1260 to make a change to the ECU, but I found the following problems:
1) the error message saying "can?t open the door"
I read that maybe the drivers of ELM327 and KWP2000+ not let it work properly. It 's true that?
2) The KWP200+ was able to read and save the dump, but the file size was 32kb. When I try to write the new file, it does not accept, because the size is 512 KB.
How do I make them accept the file size or how to change the size for KWP2000 accepted.
Thanks to all who can help and I hope that other friends can take your questions identical to mine.
Hug!
i have problems reading EDC16U1 Golf V 1.9TDI, i get SK2 error. the car is chipped, so does it mean file inside is protected? i cant even read ecu data.
works ok on other cars, i will BDM it
I have this error. Do you know what is it?
