If I help you, just press Thanks and Reputation please.
Hey there,
I currently have a 2.0 TDI Touran with 81kw/110hp
Can you help me get the coding of the ABS/ESP unit
Heres my autoscan:
Hello.
Can you help me with long code golf 7 2014year esp mk100IPB
mati1234 (8th May, 2025)
Thanks for help.
Coding accepted first and second. I calibrated the sensors. I have errors and the esp and airbag lights on and autohold
The situation is as follows:
The airbag errors have off but the ABS errors is on.
4254 - Internal Fault
B200F F0 [10001001] - -
8299 - Databus
U1121 00 [00001001] - Missing Message
In coding 1, ESP lights on and autohold faults
In coding 2, only ESP lights up
In coding 3, ESP lights on and fault: vehicle power steering system.
I think that coding no. 2 is OK. I am afraid that the purchased ABS module is damaged and causes error 4254 - Internal Fault B200F F0
After you input codding number 3.....did you make basic settings of g85, g201 and other abs sensors????
I leave you here one more code...
01FA62A124260A75037B060041CB2980462450C0608294F200 400074C002
Sorry, but I misinterpreted the error regarding 3rd coding. It's about hill hold like in the picture.
In coding no.4 only esp lights on and of course tire pressure but it always goes out at the end.
What do you think, does this error 4254 - Internal Fault B200F F0 mean bad coding or module damage?
OK, now I know everything.
I installed the new module to the old block myself.
Now I installed the new module and the new block (complete) and I no get error 4254 - Internal Fault B200F F0 . The Esp lights off.
I'm going to change the whole module and bleed the brake. I'll let you know what and how
Edber (9th May, 2025)
Hello,
On a VW Polo 2010 I have disconnected the dashboard and the ABS control unit lost the coding.
Can somebody calculate the coding for me?
I have tried these codes and not worked:
210224C24100A2E7DE5DDB16BE08FF400000 - I have calculated this according to a description.
210224C2217200B7842D24E684D800400000 - A software calculated it (hatchback).
510224C2217200B78A2D24E684D800400000 - A software calculated it (sedan).
2124210084248400401100 - I have bought this code from an online service, but this seems to be too short, I have not tried it yet.
The autoscan is attached.
Thanks in advance.
tferenc (10th May, 2025)
Thanks, monday I will post the results.
Hi!
Can someone help me with the long code, GOLF V 2009, the car has TMPS, VCDS full scan is here ...
